Possible to create cyliner baffle (internal) using topoSet or stl Mesh?
Like Tree3Likes
  • 2 Post By andre.weiner
  • 1 Post By keepfit
Old   July 25, 2013, 07:36
Default Possible to create cyliner baffle (internal) using topoSet or stl Mesh?
David Long
keepfit is on a distinguished road
Hi Foamers,
I am struggling to create internal zero-thickness cylinder wall. Having searched through the forum, but could not find any related posts about how to create curved internal patches.
It seems that topoSet can only select planar faceSet via Box. But how to select cylinder walls via topoSetDict?
So I tried another way to create such internal curved walls: generate the internal cells using 2 volumes via GMSH, and set all the BCs including the internal Cylinder BC (please take a look at the attached Picture as well as the gmsh file ). When convert the msh file using gmshToFoam, the internal BC disappeared.
SnappyHexMesh seems another way to solve this issue. By import all of the surface .stl mesh and using the new feature in OF 2.2.0 like:
refinementSurfaces
        wallCylInside  // internal cylinder wall
            level (2 2);
            faceZone wallCylInside;
            // Create baffles for all faces on the surface
            faceType baffle;
            cellZone wallCylInside;
            cellZoneInside inside;
but the snapping process failed.
So is there anybody ever faced the same issue, any advice will be appreciated.
Best,
David
keepfit is offline   Reply With Quote
Old   July 25, 2013, 09:20
Andre Weiner
andre.weiner is on a distinguished road
as i said bevor, the topoSetDict-file in the propeller tutorial is exactly what you need ( if i got your problem right :-)
It's correct that you can't select the faces directly, but you can do some boolean operations, starting with "cylinderToCell" or "surfaceToCell" as source for a cellSet. With the "surfaceToCell" source you can use a .stl-file as input.
Hope i could help you. Good luck!
Artur and ms.hashempour like this.
andre.weiner is offline   Reply With Quote
Old   July 25, 2013, 10:44
Artur's Avatar
Artur
Artur will become famous soon enough
Just to expand a bit on the previous commenter, who I agree with completely: propeller tutorial uses .obj files to snap the mesh to but you can use and .stl file just as well. As far as I remember it is possible to snap the mesh to a searchable cylinder as well but then you can't extract the features from it (not that I know of, at least) so you won't get a very good mesh.
Artur is offline   Reply With Quote
Old   August 1, 2013, 12:49
David Long
After Using snappyHexMesh to generate the internal cells, and then select the internal faces via "cylinderToCell" , delete the redundant faces via "normalToFace". As snappyHexMesh can not exactly capture the sharp edge, the selected internal faces is not perfect but acceptable.
I tried another way to do such job: generate mesh via Gmsh. As the meshes inside the internal Cylinder is created via a single Volume, hence the internal cylinder is perfect:
and the perfect internal faceSet:
Best
Daivd
mizzou likes this.
Old   February 19, 2017, 15:40
Milad
mizzou is on a distinguished road
After a long time from the last post in this forum, I've got a similar problem. I have a half (due to axissymmetry) pipe geometry and I would like to have internal half-cylinder inside my pipe. The internal half cylinder should be baffle (zero thickness internal faces) so that I can apply pressure boundary condition on that. Unfortunately I am not familiar with snappyHexMesh now. Anybody has idea how to do that?
Thanks,
Milad
mizzou is offline   Reply With Quote
createbaffles, cylinder mesh, internal patch
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[Commercial meshers] Create solid mesh around fluid mesh wcpvandervelden OpenFOAM Meshing & Mesh Conversion 0 June 21, 2012 11:05
Creating a baffle in a mesh Alexvader OpenFOAM Pre-Processing 0 September 28, 2011 12:34
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
