2D VAWT simulation - rpm ramp function?
Like Tree2Likes
  • 2 Post By linnemann
Old   July 12, 2013, 08:33
Default 2D VAWT simulation - rpm ramp function?
Anand Lobo
Boloar is on a distinguished road
Hi all,
I successfully made a 2D VAWT simulation at a constant specified RPM and wind speed.
I'd like to try a slight modification to it, namely: start the RPM at 0 and ramp it up to a given RPM, with wind speed remaining constant, so I can see the airflow interaction. How would I go about doing this?
For info: I used the AMI implementation from the pimpleDyMFoam/propeller tutorial. Based on my rudimentary programming skills, I hope I'd only need to insert some sort of ramp function into dynamicMeshDict? Or would I need to mess with the source code?
Your input is appreciated!
Boloar is offline   Reply With Quote
Old   July 25, 2013, 05:03
Default Is it possible at all?
Anand Lobo
No replies at all makes me think this is an impossible request, but I'd like confirmation of the fact in that case.
Old   July 25, 2013, 15:31
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
It is not possible using the built-in methods.
you can look at the openfoam code for solidBodyMotionFunctions
https://github.com/OpenFOAM/OpenFOAM...otionFunctions
You can take the axisRotationMotion and make a new library that could take a table as input. Similar to as how you can use a table for the BC's
https://github.com/OpenFOAM/OpenFOAM...ataEntry/Table
I know this might not be what you were looking for but that is my best bet.
I must say I do not know if it is possible to change the RPM while the case is running. That should be easy to test with your case. You might also run into problems if running in parallel.
There is also the oscillatingRotatingMotion code you could take a look at, that is definitely time varying.
https://github.com/OpenFOAM/OpenFOAM...RotatingMotion
SailorLiu and Boloar like this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   July 27, 2013, 04:28
Anand Lobo
Originally Posted by linnemann View Post
Hi
Thank you linneman, much appreciated. I'll check these out now.
This might be a good thing to put on the to-do list for future OF builds, assuming it isn't already - time-varying parameters would be useful to no end.
Old   July 30, 2013, 08:46
linnemann's Avatar
Niels Nielsen
Hi I think you are going to like this as Henry has added some of the stuff you would like.
He has added the possibility to change the omega on run-time.
More here
https://github.com/OpenFOAM/OpenFOAM...e559f51eeb8084
EDIT: See next post for table input
Linnemann
Old   August 2, 2013, 14:34
linnemann's Avatar
Niels Nielsen
Ehm I think Henry has come to your rescue :-)
I can see that from the new tutorial for interPhaseChangeDyMFoam that he uses the table as input for omega. So just upgrade to the latest git and you are good to go.
https://github.com/OpenFOAM/OpenFOAM...ynamicMeshDict
|  \\    /   O peration     | Version:  2.2.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
dynamicFvMesh   solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
    cellZone        innerCylinderSmall;
    solidBodyMotionFunction  rotatingMotion;
    rotatingMotionCoeffs
        origin      (0 0 0);
        axis        (0 1 0);
        omega       table
            (0    0)
            (0.01 419)
            (100  419)
Linnemann
Old   August 3, 2013, 04:40
Anand Lobo
Holy moly, that is awesome. It'd have to be a big table if I want fine-grain control over the RPM, but this is perfect for starters. My thanks to Henry, and thanks to you Linneman for keeping me apprised on this.
Old   August 3, 2013, 05:37
linnemann's Avatar
Niels Nielsen
Hi
The table makes linear interpolation between the entries so it does not have to be that big.
Glad to help
Linnemann
Old   August 3, 2013, 05:42
Anand Lobo
That's good, I didn't think about interpolation.
Now all I need is a computer that's somewhat less than 5 years old, to do the simulations faster, hahah
Thanks again!
2D vawt simulation meshing and fluent error daysley FLUENT 5 April 15, 2014 20:51
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
