April 17, 2013, 08:16 |
allowSystemOperation 1 giving fatal error
Mukesh Vhirodkar
I am getting following message and to rectify same i have tried to edit the controlDict file from the OpenFoam installation folder.
The main problem is I am not able to save changes to the controlDict and not able to run potentialFoam given tutorial. Can anyone help me to do this details of error as follow " fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations --> FOAM FATAL IO ERROR: Loading a shared library using case-supplied code is not enabled by default because of security issues. If you trust the code you can enable this facility be adding to the InfoSwitches setting in the system controlDict: allowSystemOperations 1 The system controlDict is either ~/.OpenFOAM/$WM_PROJECT_VERSION/controlDict or $WM_PROJECT_DIR/etc/controlDict Mukesh |
April 17, 2013, 18:34 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Mukesh,
Several months ago I explained how this can be done on the following wiki page: http://openfoamwiki.net/index.php/Ti...itional_tuning Best regards, Bruno
allowsystemoperations 1 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 02:40 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 19:54 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 07:12 |
