April 11, 2013, 09:51 |
linearUpwind
Robin Debroux
Rep Power: 14 |
I'm trying to understand the linearUpwind scheme in OpenFOAM. The linearUpwind.C isn't clear to me. So I have some questions: -Is it simply the extansion of the upwind scheme to the second order? -In the User Guide, it is said to be first/second order bounded. But for me, I would not have expected it to be bounded in the second order. Where am I wrong? Thank you. |
April 11, 2013, 17:28 |
#2 | ||
Daniel P. Combest
http://www.cfd-online.com/Forums/ope...tedlinear.html Good luck. |
April 11, 2013, 17:54 |
Robin Debroux
Rep Power: 14 |
Thank you very much for your answer!
April 19, 2013, 07:47 |
Robin Debroux
Rep Power: 14 |
Hi again,
I'm simulating a supersonic flow with a shock, inviscid case. I wanted to compare a TVD scheme (limitedLinear) with linearUpwind. I tried linearUpwind without cellLimited and then with cellLimited. What I expected was that the linearUpwind scheme without cellLimited gave me spurious oscillations but it doesn't. The two case (linearUpwind with and without cellLimited) gave me the same results. The localisation of the shock isn't very good compare to limitedLinear but I see no spurious oscillations near it. How can we explain it? Thank you. Robin |
April 20, 2013, 21:08 |
Daniel P. Combest
What type of gradient scheme are you using?
April 22, 2013, 04:28 |
Robin Debroux
Rep Power: 14 |
Gauss linear
April 23, 2013, 11:42 |
HECKMANN Frédéric
Rep Power: 17 |
give your full scheme file. Maybe you can try a leastsquare method.
April 24, 2013, 04:30 |
Robin Debroux
Rep Power: 14 |
Here is my fvSchemes for the linearUpwind case without cellLimited:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) Gauss upwind; div(phid,p) Gauss linearUpwind grad(U); div(phi,e) Gauss linearUpwind grad(U); div(phi,K) Gauss linearUpwind grad(U); div((muEff*dev2(T(grad(U))))) Gauss linear 1; } laplacianSchemes { default none; laplacian((rho*(1|A(U))),p) Gauss linear corrected; laplacian(muEff,U) Gauss linear corrected; laplacian(alphaEff,e) Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } // ************************************************** *********************** // Thank you, I'll try leastSquare method. |
April 24, 2013, 09:18 |
#9 |
HECKMANN Frédéric
Rep Power: 17 |
why you didn't put "div(phi,U)" to the second order ?
All the gradient should take the solved variable: div(phid,p) Gauss linearUpwind grad(p); div(phi,e) Gauss linearUpwind grad(e); div(phi,K) Gauss linearUpwind grad(K); |
April 24, 2013, 10:01 |
#10 |
Robin Debroux
Rep Power: 14 |
I noticed that for all the inviscid case in the tutorials, sonicFoam never use second order for this term. I've tried a second order but it doesn't improve my solution and gave me more spurious oscillations just after the shock.
Sorry for the mistake, I saw it but forgot to change it for the "linearUpwind without cellLimited" case but I didn't made the mistake for the "linearUpwind with cellLimited" case. So I don't think the mistake come from that. But I just ran the simulation with the corrections, I'll tell you if it changes something. Thank you |
June 26, 2021, 23:59 |
#11 |
Herpes Free Engineer
Rep Power: 13 |
A contribution after 8 years:
J. Guerrero's Finite Volume Method: A Crash introduction's 15th slide gives a succinct explanation for the linearUpwind scheme.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
March 16, 2022, 18:11 |
#12 |
Justyna Salachna
Rep Power: 6 |
Hi . In the slaid 15, shouldn't it be 3/2 instead of 2/3??
A few simple questions about linearUpwind and limitedLinear | chegdan | OpenFOAM | 28 | March 30, 2024 03:44 |
Why define a grad Scheme when using linearUpwind? | Benedikt | OpenFOAM Pre-Processing | 2 | August 10, 2019 09:19 |
rhoCentralFoam linearUpwind | Andy_bm | OpenFOAM Running, Solving & CFD | 8 | November 14, 2011 12:34 |
linearUpwind scheme in OpenFOAM 2.0.1 ??? | cabul | OpenFOAM | 8 | November 9, 2011 07:57 |
Discretization settings Foam vs. Fluent | wuppdupp | OpenFOAM Pre-Processing | 6 | July 25, 2009 03:35 |
