waves, forces and the pressure field with OpenFoam 1.6-ext |
April 2, 2013, 06:10 |
Max
Rep Power: 15 |
Hello everyone,
I am currently working with OpenFoam 1.6-ext to generate waves using the toolbox waves2Foam. Everything works just fine. Now I want to calculate the forces acting on a monopile due to the wave loads by using the the function "forces" (libforces.so). Therefore I need to define a pressure field "pName" but OpenFoam just calculates pd which is just a mathematical value, I guess?! So is there a way to get OpenFoam to calculate p (total pressure) and also rho? Thanks, Max |
March 9, 2017, 07:37 |
Niranjan Prabhu
Rep Power: 10 |
are you find out forces on your monopile
i stuck here, can you help me --> FOAM FATAL IO ERROR: keyword origin is undefined in dictionary "/home/user/OpenFOAM/user-2.4.0/run/work/3_waveflume/system/controlDict.functions.forces" file: /home/user/OpenFOAM/user-2.4.0/run/work/3_waveflume/system/controlDict.functions.forces from line 10 to line 24. |
forces, openfoam 1.6-ext, pressure, wavefoam, waves |
