OpenFOAM- Low Mach Number Formulation for Combustion |
February 5, 2013, 06:50 |
Anderson
Rep Power: 13 |
Hi Dear Friends,
I want to know if anybody tried to simulate combustion using low mach number model in OpenFOAM. I would be appreciate if anybody can help me Are there any solver for modeling reacting flow with Low mach number Formulation? |
February 5, 2013, 18:44 |
Rep Power: 14 |
fireFoam 1.6.0 is the one you want--Low ma number. Others are not as far as I know. They are incompressible or compressible, but obtaining the Low ma number solver only needs very small modification based on the compressible codes.
February 6, 2013, 02:29 |
Anderson
Rep Power: 13 |
Thank you for response
I want to simulate combustion in tube (3D) and channel (2D). and I think reactingFOAM is a suitable solver but I dont know How to change this solver for Low mach number flow. Can you give me some help that I can develop this solver? thank you so much |
February 6, 2013, 03:24 |
Karl-Johan Nogenmyr
Rep Power: 21 |
If your thermodynamic pressure can be considered constant throughout the simulation (i.e. not a piston engine), you'll find what you need to change here:
http://web.student.chalmers.se/group...SlidesOFW5.pdf This was for OF 1.5, but the change of reactingfoam-2.1 is straight forward. The solver works good, and has generated a number of papers: Duwig, Christophe, Sébastien Ducruix, and Denis Veynante. "Studying the Stabilization Dynamics of Swirling Partially Premixed Flames by Proper Orthogonal Decomposition." Journal of Engineering for Gas Turbines and Power 134 (2012): 101501. Duwig, Christophe, et al. "Large Eddy Simulations of a piloted lean premix jet flame using finite-rate chemistry." Combustion Theory and Modelling 15.4 (2011): 537-568. K |
February 6, 2013, 21:19 |
Rep Power: 17 |
Hello.
You may see if it helps: http://code.google.com/p/lowmachspra...lowmachSolver/ I've adapted dieselFoam 1.7 for a spray simulation in low Mach number. "pd" is the hydrodynamic pressure and "p" is the thermodynamic one. I considered the case of "p" being constant only. |
February 9, 2013, 13:15 |
Anderson
Rep Power: 13 |
Thank you for your response.
February 27, 2013, 14:12 |
Boundary Condition- Low mach number in combustion
Anderson
Rep Power: 13 |
Hi Friends
I am working on simulation combustion in channel. I change reactingfoam for solving low mach formulation. now I have some question about p. 1. I have a open system, and I set preff = 101325 (1 atm), Is it true? 2. for pd (pdynamics), I set Inlet boundary : zero gradient outlet boundary: constant 101235 but I think this is wrong because pd is calculated between 101325 , 101225 and according relation P=Pd+Preff so P is 2 atm Whereas in reference are said Pd<<preff which boundary condition must I use for pdynamic? Initial condition for pd is important? thanks a lot |
October 1, 2017, 08:04 |
Mehmet OZGUNOGLU
Rep Power: 10 |
Hi Anderson,
I have the same problem for the initial and boundary conditions. Did you get any solution. Thanks |
October 1, 2017, 14:53 |
Low Mach Formulation
#9 |
Ayush
Rep Power: 9 |
Hi Friends,
I have to develop a low Mach solver as my bachelor's project to simulate combustion of Sandia Flame D. 1.) I can't completely understand what is thermodynamic and dynamic pressures. What I get thermodynamic is used in an equation of state while dynamic pressure is used in pressure equation. Right? and How we actually get this division of pressures? 2.) Is simpeFoam is a low-mach solver? 3.) If yes can we add an equation of state to get the low Mach solver along with other equation? |
October 1, 2017, 23:56 |
#10 |
Atul Kumar
Location: National Centre for Combustion Research and Development
Rep Power: 11 |
Any where you don't solve density much more dependent on pressure change like rho/p is low Mach number solver you can see fireFoam and reactingFoam solvers based on psi n rho model also Piso n pimple formulation
Sent from my Lenovo K50a40 using CFD Online Forum mobile app |
October 2, 2017, 04:30 |
#11 |
Ayush
Rep Power: 9 |
Thank you Atul for the reply!
Could you please explain what do you mean by density much more dependent on pressure change? |
October 3, 2017, 02:41 |
#12 |
Atul Kumar
Rep Power: 11 |
Like supersonic flows where Mac h no is greater than 1 and effects of compressiblility are well seen in pressure while in low MACh no solver you don't have density coupled pressure solution n pressure is coupled with velocity
October 16, 2017, 08:28 |
#13 |
Andrea
Rep Power: 9 |
Hello everyone,
I'm having the same problems. I need to develop a Low-Mach version of reactingFoam 4.x, so I look forward to read some useful advices. I had a look at the solver developed by Mr. Nogenmyr, but I still can't understand everything. Thanks |
December 13, 2017, 12:12 |
#14 |
Malik
Rep Power: 14 |
Hello all,
I have recently been developing a solver for this exact purpose: low-Mach number solver for variable density flows. This is oriented towards combustion applications, but can also be applied to other contexts. The solver was also designed to minimize kinetic energy dissipation which is critical for Large eddy simulations (LES) and Direct Numerical Simulations (DNS). Extensive verification and validation is provided in the paper. We have been using it successfully for other purposes like soot production, spray flames and ignition problems. The paper can be found here https://www.sciencedirect.com/scienc...45793017304280 There is also a version available on arXiv if you don't have access to the journal. https://arxiv.org/abs/1705.04777 I hope it will help some of you ! Malik |
April 16, 2024, 23:00 |
#15 | |
bany
Rep Power: 8 |
Thanks for your nice work. Can you share your low-Mach number solver? And what is the difference between reactingLMFoam (https://github.com/nogenmyr/reactingLMFoam). My e-mail:banyang@tju.edu.cn Thanks a lot. |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
pre-conditioning for low mach number compressible flow solver | Shenren_CN | Main CFD Forum | 0 | April 29, 2011 22:07 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
TVD scheme at low Mach number | Axel Rohde | Main CFD Forum | 5 | August 6, 1999 03:01 |
how calculate the density in low mach number? | Juhee Lee | Main CFD Forum | 1 | July 31, 1999 16:26 |
