November 19, 2012, 01:24 |
OpenFoam Designer "tools" menu missing items
I am using the native windows version of openfoam.
When I click on paraview, it says to go into tools->manageplugins->extensions, and load plugins libPV3FoamReader and libPV3FlamReader_SM. Paraview then loads but doesn't open the example (3D view is blank except for axes and none of the drop down box options were populated (with items such as magnitude and surface). Unfortunately, I can't follow these instructions since the only thing that appears in my options menu is paraview and openFOAMconsole. |
November 19, 2012, 17:15 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings dsoodak and welcome to the forum!
The "OpenFoam Designer" was (AFAIK) a proof of concept that never got of the ground, possibly made by someone or a couple of people that were working on a master's degree. As was the whole project at http://sourceforge.net/projects/openfoam-mswin/ It has not been updated since it was released back in 2009. Nonetheless, you can find some more information about it here: http://www.cfd-online.com/Forums/ope...r-windows.html But still, I suggest that you try a more up-to-date project such as blueCFD-SingleCore instead: http://code.google.com/p/bluecfd-singlecore/ For more information on how to install ParaView to work with it, you can also browse this thread: http://www.cfd-online.com/Forums/ope...ease-help.html For even more information about OpenFOAM on Windows, you'll find a lot of information here: http://www.cfd-online.com/Forums/ope...n-windows-mac/ Best regards, Bruno
November 24, 2012, 00:43 |
thanks!
I've actually found "designer" pretty helpful even in its unfinished form. I'll take a look at the links you posted. |
[Other] Missing BC in mesh conversion from Star-cd to OpenFOAM | piccinini | OpenFOAM Meshing & Mesh Conversion | 2 | June 19, 2009 08:12 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Tutorials missing in OpenFoam 141 | jam | OpenFOAM Running, Solving & CFD | 4 | January 7, 2008 15:36 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 13:50 |
Commandline options/arguments for menu items? | jx | FLUENT | 2 | August 18, 2003 07:29 |
