November 13, 2012, 02:15 |
how to use the "yPlusRAS"utility
sqing
Rep Power: 14 |
Hi foamers
I'm solving a channel folw case with the kEpsilon model.I want the put out the Y+ and U+, but I don't know how to use the YPlusRAS utility. What's more I don't know how to get the U+. So help me please~ Thanks. |
November 13, 2012, 03:15 |
Bernhard
Rep Power: 22 |
You can just use the yPlusRAS utility from the command-line, what is not clear about it?
I think generally, the yPlusRAS utility will calculate y*, and not y+. |
November 13, 2012, 05:55 |
Daniel P. Combest
In addition to Bernhard's comment, take a look at the thread
http://www.cfd-online.com/Forums/ope...-testcase.html but make sure to take the time to read through the thread. There are corrections to the provided application and discussion about using of the contributed utility. The link I provided will give you a utility to calculate y+ and u+ and is used for low Reynolds number flows. |
November 13, 2012, 08:33 |
sqing
Rep Power: 14 |
Just like you said, I have use the yPlusRAS utility from the command-line. But I got an error ——
cannot open file file: /home/sun/OpenFOAM/sun-2.1.1/1112/constant/transportProperties at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87. FOAM exiting While there is no the transportProperties file in my case actually because I use the rhoPimpleFoam solver for my case and it maybe a bad choice for me to choose this solver. At first, I want to apply a solver from the incompressible directory because my case is a simple channel flow (1, low Re number; 2, the temperature of the inlet air is 300k,the temperature of the wall is 310k; 3, epsilon=46,k=0.7) While I find that all the cases in the incompressible directory have no dealing with the temperature and I don't know how to add it in the solver, so I chose the rhoPimpleFoam solver for my case and I don't know if it is a right one. In your opinion, what solver should I choose? What's more, what is y* ? |
November 13, 2012, 08:36 |
#5 | |
sqing
Rep Power: 14 |
First, thanks for your reply. Just like you said, I have use the yPlusRAS utility from the command-line. But I got an error —— cannot open file file: /home/sun/OpenFOAM/sun-2.1.1/1112/constant/transportProperties at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87. FOAM exiting While there is no the transportProperties file in my case actually because I use the rhoPimpleFoam solver for my case and it maybe a bad choice for me to choose this solver. At first, I want to apply a solver from the incompressible directory because my case is a simple channel flow (1, low Re number; 2, the temperature of the inlet air is 300k,the temperature of the wall is 310k; 3, epsilon=46,k=0.7) While I find that all the cases in the incompressible directory have no dealing with the temperature and I don't know how to add it in the solver, so I chose the rhoPimpleFoam solver for my case and I don't know if it is a right one. In your opinion, what solver should I choose? What's more, what is y* ? |
November 13, 2012, 08:39 |
#6 | |
sqing
Rep Power: 14 |
Dear Dan Thanks for your reply. It's very helpful for me. Thanks again! |
November 13, 2012, 17:34 |
Rep Power: 17 |
since you are using a compressible solver, use yplusRAS -compressible
November 13, 2012, 22:00 |
sqing
Rep Power: 14 |
November 20, 2012, 10:52 |
#9 |
sqing
Rep Power: 14 |
November 20, 2012, 10:58 |
#10 | |
Daniel P. Combest
http://www.cfd-online.com/Forums/ope...lus-ystar.html |
November 20, 2012, 11:01 |
#11 | |
sqing
Rep Power: 14 |
Thank you very much Sunxing |
December 5, 2017, 11:22 |
#12 |
Lennart
Rep Power: 10 |
Just an update, the yPlus tool has been moved into the solvers:
yPlus has been superceded by the '-postProcess' solver command-line option, e.g. simpleFoam -postProcess -func yPlus |
January 11, 2018, 02:08 |
#13 |
Rep Power: 10 |
