Average temperature in a portion of my domain
Like Tree1Likes
  • 1 Post By fcollonv
Old   November 12, 2012, 10:58
Default Average temperature in a portion of my domain
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am trying to figure out if-and-how it is possible to evaluate the avarage temperature in a certain zone of my domain (i.e. in all the cells with x < x_0).
Could anyone help?
Thanks a lot
samiam1000 is offline   Reply With Quote
Old   November 12, 2012, 15:04
Frederic Collonval
Location: Technische Universitaet Munich - Lehrstuhl fuer Thermodynamik
fcollonv is on a distinguished road
Hey Samuele,
Do you want the average in time for a portion of your domain or the average in space of a portion of your domain??
In the first case look in
src/postProcessing/functionObjects/field/fieldAverage/fieldAverage/fieldAverage.H
In the second case look in
src/postProcessing/functionObjects/field/fieldValues/cellSource/cellSource.H
The function object system will save you
Or you can do it in ParaView, Selecting the wanted cells then applying the filter "Integrate variables" on that selection.
Good luck
Frederic
davcrisp likes this.
Frederic Collonval
Technische Universität München
Thermodynamics Dpt.
fcollonv is offline   Reply With Quote
Old   November 26, 2012, 05:07
Samuele Z
Hi Frederic and thanks for answering.
Actually, I don't know why, but I got the notification of your asnwer today. Sorry.
Anyway, I am looking for the mean in space. The point is that "integrate variable" in paraview doesn't work (better, I am not able to make it work!)..
I'll try a bit more and then I will move on the function.
Thanks a lot,
Samuele
Old   November 26, 2012, 07:11
Default Selection in Paraview
Frederic Collonval
Hey Samuele
I advice you to have a look at the chapter 2.1 of the Paraview tutorial (I have the one for the version 3.12 - you can download it there http://paraview.org/Wiki/The_ParaView_Tutorial )
Then apply the filter "Integrate variables" on the selection. In the spreadsheet, switch attribute from Point Data to Cell Data. Then to have the volume average of T, divide the value under the T column by the Volume.
Good luck,
Frederic
Frederic Collonval
Thermodynamics Dpt.
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Computing Average Temperature using DEFINE_ADJUST macro T81 Fluent UDF and Scheme Programming 13 October 16, 2017 07:58
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
Average Temperature in Domain haka FLUENT 1 August 17, 2011 07:25
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
