Mesh in LES
Like Tree1Likes
  • 1 Post By Djub
Old   November 8, 2012, 12:07
Default Mesh in LES
Julien
Djub is on a distinguished road
Hi every Foamers!
I have read somewhere (but I can't remember where !!!) that mesh refinement was forbidden in LES, because the filtering operator has to permute with integral and derivative ones, which is possible only if delta is not constant. Does anybody confirm this?
I easily admit this. If there is a "large" cell close to a "small" one (let's say half), how to make comunicating the cells concerning the eddies modelled in the large cell and calculated in the small cell !?! Thus, I understand that a mesh has to be uniform. At least changing very smoothly.
On the other hand, I can read a lot of papers with refined meshs close to the walls and bluff bodies. How can this be ?
Anyone to explain me?
hulli likes this.
Djub is offline   Reply With Quote
Old   November 8, 2012, 12:48
Julien
I've got it:
Alberto Passalacqua wrote:
You need good and prett uniform mesh anyways for LES, since you are assuming the filter operator and the differential operator are commutative, which is not true on non-uniform grids!
(see this thread)
Old   November 9, 2012, 11:25
Bernhard
Bernhard is on a distinguished road
The point for a good LES simulation, is that you want to resolve 80% of the energy spectrum. Near the wall, you will have more energy in the smaller scales, so you need a fine grid there. Only in LES, you want to have cells with a low aspect ratio (which is not necessary in RANS), so you need to refine them in all three directions. If you apply that refinement globally, the amount of cells will get out of hand quite soon. So it is more a compromise to still perform LES.
Be sure to check out the PhD thesis by Eugene de Villiers, (see http://foamcfd.org/resources/theses.html ), he is addressing some of the issues you mention.
Bernhard is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
Numerical oscillations in LES due to mesh refinement Soder OpenFOAM 0 June 14, 2011 11:10
LES mesh guidelines John Deas FLUENT 2 December 1, 2007 05:56
mesh requirement for LES Jason Main CFD Forum 1 February 10, 2004 17:48
