porousBafflepressure BC
Like Tree5Likes
  • 1 Post By laurent257
  • 4 Post By laurent257
Old   August 24, 2012, 10:58
Default porousBafflepressure BC
laurent dilain
laurent257 is on a distinguished road
Hey everyone !
I'm new on this forum and quite beginner on Openfoam.
I used to work with Fluent or Star-CD since many years, and my first experiences with OpenFoam are very encouraging but now, I can't go further without a little help...
I know that this problem has already been discussed in the forum and I let a reply on another thread. But, to be sure that everyone can see it, I open a new thread.
I want to simulate a pressure loss as for a filter and I try to use the porousBafflePressure BC on a simple case (for the moment).
This case is very simple, to begin, with an incompressible flow, no heat transfer, one phase, etc... It's just a cylinder including a normal surface supposed to act as a filter.
This same model works fine with the fan BC with simpleFoam but I am unable to make it work with the porousBafflePressure BC under porousSimpleFoam, for instance...
I have modified my controlDict file by adding a lib reference as in the example of the dambreakPorousbaffle ("libturbulenceDerivedFvPatchFields.so") but it doesn't work.
My questions are :
- Do have I to use interFoam to use this porousBaffle BC, even with a so simple case ? In this case, where can I fond a good explanation for the use of this solver ?
- If not, where can I find a detailed explanation of what to do to use it ?
Thank you very much for your answers or help !!
Laurent
mizzou likes this.
laurent257 is offline   Reply With Quote
Old   August 24, 2012, 17:49
laurent dilain
Hello again !
I admit I played at the apprentice's sorcerer (litterally translated from french ) and I regret a little, but now, I am able to launch the computation. It crashes, but I think now it's due to my model or the values of the BC.
Anyway, I think it can be useful to other member that I explain what I've done :
From the model which worked with the Fan BC (with the good conditions for U, ... of course !) :
- I changed the definition of the boundary conditions in the 'p' file, by copying those given in the example with porousBafflePressure (see upper).
- I also added the file 'changeDictionaryDict' in the System dir., with the same values as in the 'p' file.
- I added the library info in the controlDict file :
'libs
I used the solver porousSimpleFoam and it worked. The computation begins. At this stage, the calculation crashes after several iterations and I have to find why, but it's a real progress !
If someone can tell me if I forgot something, it could be great !
Or if someone can tell me where it's possible to find a good explanation on how to use all these parameters...
Thank you very much for your help or further information !
Bye !
Laurent
mizzou, sk11, mixkats and 1 others like this.
pressure or porous jump boundary condition Rezaslosh OpenFOAM 14 July 6, 2016 03:28
porousBafflePressure BC condition dpeinado OpenFOAM Running, Solving & CFD 0 October 21, 2011 10:16
