Adding a new term in momentum equation of Interfoam
Like Tree2Likes
  • 1 Post By udiitm
  • 1 Post By vahid.najafi
Old   June 29, 2012, 07:02
Default Adding a new term in momentum equation of Interfoam
yudhast
udiitm is on a distinguished road
Dear All,
I need a help in implementing a modified surface tension component ( F
st,i ) in interfoam.
This surface tension force is implemented in Interfoam as
fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1)
which is basically
Fst,i = -sigmaK*grad (alpha1)
This part I need to change it to
F
st,i = -(Pb - Pa) * grad (alpha1)
where
(Pb - Pa) = 0.5* ( P1 + P2 )
P1 =0.5* ((1-2*alpha1)* P)w + ((1-2*alpha1)* P)E
P2 =0.5* ((1-2*alpha1)* P)N +
((1-2*alpha1)* P)S
Here W,E,N and S represents left, right, top and bottom cell information for a cell "i"
Thanks in advance
YUdhast
Zhiheng Wang likes this.
udiitm is offline   Reply With Quote
Old   July 29, 2012, 03:35
Default plese help me
vahid
vahid.najafi is an unknown quantity at this point
Hi Dear yudhast.
I'm working with openFoam 2.0.1,and have a problem with solver (interPhaseChangeFoam) in multiphase solvers.
I want to add (surface tension or sigma ) in a part of this solver, in directory:
/run/myinterPhaseChangeFoam/phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.c
I added sigma() in this code:
Foam::tmp<Foam::volScalarField>
Foam:haseChangeTwoPhaseMixtures::SchnerrSauer: Coeff
const volScalarField& p
) const
volScalarField limitedAlpha1(min(max(alpha1_, scalar(0)), scalar(1)));
volScalarField rho
limitedAlpha1*rho1() + (scalar(1) - limitedAlpha1)*rho2()
return
return
//......I want to change it( <<sigma>> surface tension multiple in it):
(3*rho1()*rho2())*sqrt(2/(3*rho1()))*sigma()
*rRb(limitedAlpha1)/(rho*sqrt(mag(p - pSat()) + 0.01*pSat()));
dont successful wmake, and seen(sigma() was not declared ):
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:113: error: sigma() was not declared in this scope
make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Error 1
please help me.
vahid.najafi is offline   Reply With Quote
Old   July 29, 2012, 04:21
Default again.
vahid
Hi again.
I added interpolate(interface.sigma())
in this code:
) const
volScalarField rho
return
(3*rho1()*rho2())*sqrt(2/(3*rho1()))*interpolate(interface.sigma())
dont successful wmake, and seen(was not declared ):
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:113: error: 'interface' was not declared in this scope
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:113: error: 'interpolate' was not declared in this scope
please help me.
Old   July 29, 2012, 04:30
Default again.
vahid
please help me????
Old   July 29, 2012, 09:37
Nima Samkhaniani
nimasam is on a distinguished road
dear vahid
i recommend you to read a C++ book, chapter "class"
interface is object!
interpolation is a function or member of a class
when you call an object, you should first define it some where
first, you should add the appropriate header file, for example:
#include "fvCFD.H"
then you can use public member of this class
fvc::interpolate(....)
nimasam is offline   Reply With Quote
Old   July 29, 2012, 11:52
Default Thanks
vahid
Thanks nima for your answer
adding term, interfoam, surface tension
Momentum equation of interFoam? cfdfans OpenFOAM 10 May 9, 2018 03:43
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Adding a source term to concervation of species equation bernarde STAR-CCM+ 0 June 4, 2009 04:17
Momentum equation used by mixture model George FLUENT 0 May 19, 2005 14:07
bouyancy term in epsilon equation Michael Main CFD Forum 1 June 25, 1999 11:20
