Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Comparing OF11 Simulations with DTC Experimental Results : Any Suggestions?
Like Tree1Likes
  • 1 Post By JNSN
Old   June 17, 2024, 15:24
Default Comparing OF11 Simulations with DTC Experimental Results : Any Suggestions?
jbo
jbo is on a distinguished road
Hello everyone,
I have a little experience with FineMarine in the context of ship resistance. Currently, I am experimenting with OpenFoam 11. I have downloaded the DTC Hull tutorial from OpenFoam 10 and have run it without making any changes.
I am comparing the results with the following paper:
el Moctar, Ould & Shigunov, Vladimir & Zorn, Tobias. (2012). Duisburg Test Case: Post-Panamax Container Ship for Benchmarking. Ship Technology Research. 59. 50-64. 10.1179/str.2012.59.3.004.
Here are the results:
m/s simul. exp.
1.335 14.46 20.34
1.401 17.40 22.06
1.469 19.96 24.14
1.535 24.24 26.46
1.602 23.50 28.99
1.668 25.32 31.83
The size, velocity, temperature, and other parameters are the same. I assume this tutorial was created specifically for this purpose.
I am sure many of you have already done this exercise, but I can't find answers to the following questions:
  1. Such a difference... Is it just a simulation issue, or is the setup different as well? (For example, are there differences in the appendages?)
  2. Is there a better tutorial or setup to compare OpenFoam 11 with experimental measurements?
I look forward to hearing from you.
jbo is offline   Reply With Quote
Old   July 9, 2024, 17:32
Will Kernkamp
wkernkamp is on a distinguished road
I plotted your result against the experiment. Are you sure that your runs are fully converged? The test cases are sometimes limited in the number of iterations to limit the test times.
wkernkamp is offline   Reply With Quote
Old   July 10, 2024, 16:57
jbo
To be honest I don't know. I just assumed the tutorials were designed to showcase best practices.
This is the controlDict I ran :
https://raw.githubusercontent.com/Op...em/controlDict
Any tips to get closer simulation ?
By the way I am not even sure whether or not appendages where present in Moctar 2012 experiments. What did you conclude ?
Regards
Julien
Old   July 11, 2024, 06:56
JNSN's Avatar
Jan
JNSN is on a distinguished road
Hi Julien,
from the controlDict you shared it seems you are running "DTCHull", which means time scheme LTS (pseude transient) and fixed hull (no trim and sinkage).
From my experience it is hard to get a converged solution with LTS, at least with the tutorial settings.
I suggest have a look at the "DTCHullMoving". This should be a good starting point.
Regarding the experimental setup: The resistance tests had been done with rudder.
In case you want to include the rudder, the geometry can be found on the website of University of Duisburg-Essen: https://www.uni-due.de/ismt/ismt_dui...est_case.shtml
Best,
Jan
jbo likes this.
JNSN is offline   Reply With Quote
Compare different simulations results bernoulli12 STAR-CCM+ 1 July 16, 2022 22:18
How to find centrifugal pump CAD geometry with experimental results for benchmarking? jgross Main CFD Forum 1 October 18, 2021 13:47
Validation of 2D simulation and experimental results mizzou OpenFOAM Running, Solving & CFD 8 April 4, 2017 10:31
Comparing Experimental and Computational results. New Main CFD Forum 0 September 27, 2007 13:08
Need experimental results on turbulent flow babyface Main CFD Forum 1 May 22, 2002 13:52
