Superficial Reynolds number for two phase flow |
Akshay
Rep Power: 6 ![]() |
Hi Fomers, I am trying to validate interFoam solver for two phase flow in a pipe, but had trouble calculating the velocities of 2 phases using the provided Reynolds number.
My test case is a pipe of 10mm diameter and 1.5m length. Re(liquid) = 6000 and Re(gas) = 832. Can someone please provide your valuable suggestion on how I can find the velocity of 2 phases using the available Reynolds number? I have attached the URL of the research paper and also the fluid properties. https://www.researchgate.net/profile...G-OPENFOAM.pdf fluid_properties.png |
Uwe Pilz
Rep Power: 15 ![]() |
The text gives superficial Re numbers.
The superficial value of Re is the one that each phase would have if the flow of that phase were flowing through the channel by itself.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Seakeeping Solver:Crashed | akbarbagusd | Fidelity CFD | 0 | November 5, 2021 12:42 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
AMI interDyMFoam for mixer | danny123 | OpenFOAM Running, Solving & CFD | 4 | June 19, 2013 04:49 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
