Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
interFoam validation for coolant flow in fusion Reactor
Like Tree1Likes
  • 1 Post By akidess
Old   March 22, 2016, 02:05
Default interFoam validation for coolant flow in fusion Reactor
vipin
vipin1431 is on a distinguished road
I am using OpenFoam tool for simulating Two phase Flow problem using InterFoam. I get good results when I used ratio of dynamic viscosity (mu1/mu2=1,20,100)but when I used actual value (Lead lithium = 0.0000000394*9926 (nu*density) and helium=.00108823529*0.034), I am not getting results. Anybody knows what is the problem? plz see the file attached for velocity profile
vipin1431 is offline   Reply With Quote
Old   March 22, 2016, 03:42
akidess's Avatar
Anton Kidess
It seems to me your lead viscosity is 10x smaller than it should be. Furthermore, your post is of very poor quality. Label the axis on your image, and properly describe why the result you are getting is not what you expect. Read this post:
http://www.cfd-online.com/Forums/ope...-get-help.html
vipin1431 likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   March 23, 2016, 02:10
vipin
sorry for poor quality of post.
I used kinematic viscosity of lead lithium as 3.94*10-8.
I had attached the validation results when viscosity ratio of two fluid is 5.37 (viscosity ratio 5.37 mean I take one fluid's viscosity as 1 and other as 5.37 (fictitious fluid)) and it quite matches with the results publish in research paper.
but when I used actual value as mention in above post, I get stiff gradient in lead lithium side and then velocity become almost zero and again get parabolic curve for helium.
I am not sure that above results good as shown in attached file velocity profile and alpha. I am expecting the results as in attached file image.
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 01:52
interFoam more Axi-symmetric two phase flow ? Ingenierias2003 OpenFOAM 4 May 10, 2010 15:39
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
