Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Jump in epsilon values near the wall : low re k-epsilon model
Like Tree1Likes
  • 1 Post By maHein
Old   January 25, 2013, 07:09
Default Jump in epsilon values near the wall : low re k-epsilon model
Malik
malaboss is on a distinguished road
Hi FOAMers !
I am now studying an airfoil profile which small chord makes it look like a cylinder.
The thickness of the airfoil is about several cm and the velocity at the inlet is 10m/s.
I considered my fluid as incompressible due to low velocities.
k at the inlet is 1.5 ( 10% of turbulence)
epsilon at the inlet is (19,2, I choosed the highest mixing length that I considered to be about half of the airfoil thickness)
First, I tried to use a (high reynolds) k epsilon turbulence model with a wall function. It gave me some weird as epsilon near the wall was really high : several tens of thousands.
I saw in the following tutorial /tutorials/incompressible/simpleFoam/pitzDaily similar values.
Is it OK to have such great values near the wall for epsilon ?
Then, I decided to use a low Re kepsilon model launderSharma, and by initializing k an epsilon near to zero close to the wall (as it is done in the incompressible/boundaryFoam/boundaryLaunderSharma tutorial) I find a high jump for my espilon values as you can see in the pictures :
the first one is the espilonfield and the second one is the plotting of epsilon values in the radial direction.
I already checked y+ values and i the average is lower than 1.
I guess I should not have that result. Do you know why i get this and how to fix it ?
If you need it, I can provide more information about my dictionnaries.
Thanks to all for your help
malaboss is offline   Reply With Quote
Old   February 1, 2013, 17:36
maHein is on a distinguished road
High values for dissipation near the wall are normal. Just have a look at the validation simulation of a flow ofer a flat plate performed by NASA http://www.grc.nasa.gov/WWW/wind/val.../fpturb01.html. You could just convert your data to dimensionless epsilon+ and compare it to the validation results.
bmikuz likes this.
maHein is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Values of k & epsilon in the moving wall ghlee Main CFD Forum 1 August 16, 1999 13:42
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
