Modelling falling solid sphere using interFoam VOF model
Like Tree1Likes
  • 1 Post By eelcovv
Old   March 27, 2012, 11:52
Default Modelling falling solid sphere using interFoam VOF model
Eelco van Vliet
eelcovv is on a distinguished road
Dear Foamers,
I have been trying to model a falling perspex sphere in water using interFoam. I figured that choosing a large surface tension and dynamic viscosity would allow to represent the perspex sphere by the second liquid phase: the high surface tension should ensure a spherical shape and the high dynamic viscosity should prevent internal fluid circulations in the sphere.
With my first attemp I find that the terminal falling velocity is way too small compared to what I expect. I assume a 3 mm sphere (density 2200 kg/m3) in water (1000 kg/m3), hence I expect to find a velocity of about 0.33 m/s However, I find a velocity of about 1 mm/s, which is an order 100 too small. Please find attached a view on the velocity field and pressure distribution over the particle (bubble).
My quesions are:
1) Is it in priciple allowed to use VOF for falling object such as small particles?
2) Has anybody simulated solid spheres with VOF ?
3) Could anybody comment on my numerical settings?
My impression is that the difficulty is the large pressure inside of the bubble due to the 2*sigma/R bubble pressure. I have choosen sigma as small as possible (0.1 N/m) in order to keep the internal bubble pressure as low as possible. Nevertheless, for R=3 mm this would still lead to a P=2*0.1/3e-3=67 N/m. The hydrostatic pressure over the bubble (which takes care of the buyancy force) is 30 Pa. The pressure I find in the bubble is actually higher than anticipated: about 400 Pa. Perhaps the large pressure drop over the bubble interface give problems ?
Well, anyway, in case anybody can say anything sensible about it. Please let me know. I will include a summary of my numerical and physical settings below.
Some remarks: I have already varried some things. I checked a different gradScheme interpolation (see fvSchemes): cellMDLimited insteat of Gauss lnear. I have varied the resolution already. This mesh already uses 0.5 mlj cells. The grid was made with blockMesh and some grid refinement in the bubble areay with snappyHexMesh. Also I have tried a large surface tenstion (1 N/m), but none of it leads to a higher falling velocity
Well. That's it. Any suggestions appreciated!
Regards
Eelco
constant/transportProperties
phase1
    transportModel  Newtonian;
    nu              nu [0 2 -1 0 0 0 0] 1.0e-06;
    rho             rho [1 -3 0 0 0 0 0] 1000;
   sigmaC           sigmaC   [-1 -3  3 0 0  2 0 ] 22;
phase2
    nu              nu [0 2 -1 0 0 0 0]  1;
    rho             rho [1 -3 0 0 0 0 0] 2200;
    sigmaC           sigmaC   [-1 -3  3 0 0  2 0 ] 1e-10;
sigma           sigma [1 0 -2 0 0 0 0] 0.1;
0/U
    top
        type            slip;
    bottom
        type            pressureInletOutletVelocity;
        value           uniform ( 0 0 0 );
    front
        type            slip;
    back
        type            slip;
    ambient
        type            slip;
    wall
        type            slip;
0/p_rgh
boundaryField
    top
        type            fixedValue;
        value           uniform 0;
    bottom
        type            buoyantPressure;
    wall
    back
    ambient
    front
0/alpha1
boundaryField
    top
        type            zeroGradient;
    bottom
        type            zeroGradient;
    wall
        type            zeroGradient;
    back
        type            zeroGradient;
    ambient
        type            zeroGradient;
    front
        type            zeroGradient;
system/controlDict
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         100.0;
deltaT          1e-5;
writeControl    adjustableRunTime;
writeInterval   1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
system/fvSolution
|  \\    /   O peration     | Version:  2.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    pcorr
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       1e-10;
            relTol          0;
            smoother        DICGaussSeidel;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            cacheAgglomeration false;
            nCellsInCoarsestLevel 10;
            agglomerator    faceAreaPair;
            mergeLevels     1;
        tolerance       1e-10;
        relTol          0;
        maxIter         100;
    "(p_rgh|Psi)"
        solver          GAMG;
        tolerance       1e-07;
        relTol          0.01;
        smoother        GaussSeidel;
        cacheAgglomeration true;
        mergeLevels     1;
    "(p_rgh|Psi)Final"
        $p_rgh;
        relTol          0;
    "(Bf|U|T|k|epsilon|omega|R|omega)"
        solver          GAMG;
        tolerance       1e-07;
        relTol          0.1;
        mergeLevels     1;
    "(U|k)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nCorrectors     3;
    nNonOrthogonalCorrectors 2;
    nAlphaCorr      1;
    nAlphaSubCycles 4;
    cAlpha          1;
system/fvSchemes
|  \\    /   O peration     | Version:  2.0.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
//    default CrankNicholson 1;
    default         Euler;
gradSchemes
//    default    Gauss linear;
          default     cellMDLimited Gauss linear 1.0;
      div(rho*phi,U) Gauss linearUpwind cellLimited Gauss linear 1;
divSchemes
    div(rho*phi,U)  Gauss limitedLinearV 1;
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression;
laplacianSchemes
    default         Gauss linear corrected;
    laplacian(gamma,Psi) Gauss harmonic uncorrected;
interpolationSchemes
    default         linear;
//    gamma             Gauss harmonic uncorrected;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha1;
aspsarv likes this.
eelcovv is offline   Reply With Quote
Old   March 28, 2012, 08:54
Olivier
olivierG is on a distinguished road
hello,
You should try with a smaller viscosity ratio, 1e6 is too much and may give youstrong parasitic current/numerical artefacts ...
so try a a viscosity ratio of 1e3. (i.e nu2 ~1e-3)
regards,
olivier
olivierG is offline   Reply With Quote
Old   April 2, 2012, 09:10
Default viscosity dependence
Eelco van Vliet
Hi Olivier
Thanks for the remark. It indeed appears that the ratio nu_fluid/nu_bubble was choosen too large. I have run a few cases with varying bubble viscosity. Ideally the bubble viscosity is as large as possible (to mimic a solid sphere). For lower viscosities you can anticipate a different drag coefficient of the bubble, given by
Cd=(16/Re)*((1+(3mu_p)/(2*mu_f))/(1+mu_p/mu_f))
(analytical solution for Rep<1 by Hadammard,1911)
For mu_p<<mu_f this give Cd=16/Re (stokes flow of gas bubble) and for mu_p>>mu_f this gives Cd=24/Re (stokes flow for particle). Clearly, I am not in Stokes regime, nevertheless, if I use this relation I would say that for my choise of nu_p=1e-3 m2/s -> mu_p=rho*nu_p=2.2 Pa s I am in the limit of spherical particles as Cd -> 24/Re.
Well, I run a few values of nu_p; attached the graph of the position X_p and velocity U_p of each value, incl the analytical solution for a true spherical particle. As you can see, now indeed I am in the right ball park. My previous value of nu_p (of 0.01 m2/s) gave way too low terminal falling speed, but as soon you go below 2e-3 m2/s for the kinematic viscity (i.e. take nu_p/nu_f < 1000), the terminal rising speed is reasonably well predicted.
My only concern now is that the terminal falling velocity is very sensitive to the exact choise of nu_p, whereas the values taken should all be in the limit that Cd-> 24/Re, hence still lead to the same terminal falling velocity. Perhaps this is due to differences in the deformation of the sphere. I will check the influence of the surface tension. But anybody with further suggestions: any comments appreciated:-)
Regards
Eelco
Old   November 28, 2012, 04:57
Dongyue Li
sharonyue is on a distinguished road
Hi, if you want to simulate a perspex sphere droping in water, I dont know why you can change the nu of water, afaik,the nu of water is a constant if you dont considerate T or something.
by the way, you sphere is so small, have you ever tried a larger diameter? such as 1cm steel ball?
sharonyue is offline   Reply With Quote
Old   November 28, 2012, 06:06
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
Hi Eelco,
There is a group in Sweden performing quite a lot of simulations on settling of solid particles using VOF. Here is one of their paper:
A novelmultiphase DNS approach for handling solid particles in a rarefied gas
H. Ströma, b, , , S. Sasicc, , B. Anderssona, b,
http://dx.doi.org/10.1016/j.ijmultip...ow.2011.03.011
Cheers,
Duong
duongquaphim is offline   Reply With Quote
Old   January 16, 2013, 03:37
emirust is on a distinguished road
Hey Eelcov,
You mention you perform a grid refinement in the region close to the bubble with snapphyHexMesh. How exactly are you doing this?
Thanks!
Edit: more infor can be found : http://www.cfd-online.com/Forums/ope...plet-fall.html
emirust is offline   Reply With Quote
Old   August 7, 2021, 22:52
Default Modelling A solid particle dropping into a Tank
Arnold
aspsarv is on a distinguished road
Hello ever one,
Could you please let me know how I can model a solid drop into a tank?
Which solver do you recommend?
I have three phase of solid gas and liquid. Interfoam works? what about VOF?
aspsarv is offline   Reply With Quote
error message cuteapathy CFX 14 March 20, 2012 07:45
plz rply urgent regrding vof model for my system garima chaudhary FLUENT 1 July 20, 2007 09:37
urgent query regarding vof model plz rply Garima Chaudhary FLUENT 0 July 13, 2007 03:20
Modelling flow around a ship's hull using vof Manoj Kumar FLUENT 0 February 26, 2005 17:22
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
