which schemes are mixed using the "blended" scheme?
Like Tree2Likes
  • 2 Post By stevenvanharen
Old   March 13, 2012, 05:13
Default which schemes are mixed using the "blended" scheme?
Jan Östh
Jan.Östh is on a distinguished road
Hi
I'm using v2.1.0. When using the blended scheme for the divergence in the momentum equations, which schemes are actually blended?
Is it standard Central Differencing (CD) scheme of second order accurancy and a Upwind Scheme of second order, or is it CD and Upwind of first order?
I use the blended scheme by setting the following in fvSchemes:
divSchemes
default none;
div(phi,U) Gauss blended 0.9;
Is this correct?
Kind regards
Jan
Jan.Östh is offline   Reply With Quote
Old   March 13, 2012, 11:30
Steven van Haren
stevenvanharen is on a distinguished road
blended blends with CD and first order Upwind
You can find this in:
$FOAM_SRC/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/blended
You can also check out the other schemes you might need here.
stevenvanharen is offline   Reply With Quote
How to implement power law or hybrid schemes?? kamkari OpenFOAM Programming & Development 13 January 13, 2018 07:35
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 13:29
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result gemini Main CFD Forum 12 December 27, 2011 22:01
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
Standard for checking and testing numerical schemes? X. Ye Main CFD Forum 7 August 31, 1999 18:05
