March 1, 2012, 06:33 |
What is the "best" decompostition method?
Attesz
Rep Power: 17 |
I'm dealing with an axial fan of 3 regions, and I'm currently using the scotch decomposition method. In your opinion, what is the best decomp. method for such cases (long domain, 2 interface). I'm thinking about the structured method... |
March 1, 2012, 08:56 |
Olivier
Rep Power: 18 |
hello, just my 2 cents
From some test i made some time ago, ... it depend of your geometry. - With "simple" one like pipe and / or very elongated in one or two direction, try the simple/ hierarchical method in the corresponding direction. - with no clear direction, scotch will do a very good job. regards, olivier |
March 1, 2012, 09:09 |
Attesz
Rep Power: 17 |
Thanks Olivier. My geometry is elongated in y direction, but I'll run on 16cores or more. Decomposing the geometry as (2 4 2) could be a good start in your opinion?
March 1, 2012, 09:32 |
Olivier
Rep Power: 18 |
No, if your geometry is on the y axis, i would try (1 16 1).
But make a small bench, and you would get your answer ... regards, olivier |
March 1, 2012, 09:34 |
#5 | |
Attesz
Rep Power: 17 |
best, Attila |
March 1, 2012, 09:48 |
Olivier
Rep Power: 18 |
then decompose using different setting, and sum the total of exchange face: the less = the best.
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
Fluent 6.3.26 vs 12.1 and partition method | Anorky | FLUENT | 0 | April 27, 2010 10:55 |
Comparison: Finite Volume Method vs. Analytic Method | m-fry | Main CFD Forum | 1 | April 20, 2010 14:40 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
Help about the preconditioner in gmres method | Dan Gao | Main CFD Forum | 3 | July 5, 2008 01:18 |
