AMG as preconditioner
Like Tree2Likes
  • 2 Post By alberto
Old   February 23, 2012, 06:54
Default AMG as preconditioner
HaZe is on a distinguished road
after my first Problems with AMG as solver, I'm trying to use AMG as preconditioner like in the papers [1] and [2] from Hrv.
For GAMG as solver with preconditioner AMG it works well (I did this for proof of concept, if AMG as preconditioner works in my OF installation).
But it doesn't work with CG-methods.
This is my ./system/fvSolution:
solvers
        "(omega|rho|U|Yi|hs|k|epsilon)"
        solver PBiCG;
        tolerance 1e-6;
        relTol    0;
        minIter 0;
        maxIter 1000;
                preconditioner
                         preconditioner AMG;
                         cycle W-cycle;
                         nMaxLevels 100;
                         scale off;
                         policy AAMG;
                         groupSize 4;
                         minCoarseEqns 20;
                         smoother GaussSeidel;
                         nPreSweeps 2;
                         nPostSweeps 2;
                         scaleCorrection true;
                         directSolveCoarsest false;
                         cacheAgglomeration true;
                         nCellsInCoarsestLevel 10;
                         agglomerator faceAreaPair;
                         mergeLevels 1;
        p
        solver PCG;
        tolerance 1e-9;
        relTol    0;
        minIter 0;
        maxIter 1000;
        preconditioner
                         preconditioner AMG;
                         cycle W-cycle;
                         nMaxLevels 100;
                         scale off;
                         policy AAMG;
                         groupSize 4;
                         minCoarseEqns 20;
                         nPreSweeps 2;
                         nPostSweeps 2;
                         mergeLevels 1;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
And the resulting error message:
Creating field DpDt
Courant Number mean: 2.98621e-05 max: 0.0562667 velocity magnitude: 42.2
Starting time loop
Courant Number mean: 5.30599e-05 max: 0.0999763 velocity magnitude: 42.2
deltaT = 1.77683e-05
Time = 1.77683e-05
Solving chemistry
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
[0] [1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Not implemented[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] Not implemented
[2]
[2]     From function AMG::preconditionT(scalarField& wT, const scalarField& rT, const direction cmpt)
[2] [3]
[3]
[3] --> FOAM FATAL ERROR:
[3] Not implemented
[3]
[3]     From function AMG::preconditionT(scalarField& wT, const scalarField& rT, const direction cmpt)
[3]     in file /build/buildd/openfoam-1.6-ext-1.6.0/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/lduMatrix.H at line
[1]
[1]     From function AMG::preconditionT(scalarField& wT, const scalarField& rT, const direction cmpt)
[1]     in file /build/buildd/openfoam-1.6-ext-1.6.0/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/lduMatrix.H at line 725.
[1]
FOAM parallel run aborting
[1]
[2]
[2]
What does this mean? Am I not able to use AMG preconditioning for PCG and PBiCG solvers? But why does it work then for GAMG? I'm using OF1.6ext.
The "banana" test for getting the available preconditioners, shows me AMG among others.
I hope somebody can help me with this.
Greetings,
HaZe.
HaZe is offline   Reply With Quote
Old   February 24, 2012, 03:32
Alberto Passalacqua
You should be able to use it with the PCG solver only. In OpenFOAM 2.1.x the syntax is
    p
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       1e-08;
            relTol          0;
            smoother        DICGaussSeidel;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            cacheAgglomeration false;
            mergeLevels     1;
        tolerance       1e-08;
        relTol           0;
        maxIter         100;
With PBiCG you can use the DILU preconditioner.
Best,
Alberto Passalacqua
Old   February 24, 2012, 04:07
Originally Posted by alberto View Post
You should be able to use it with the PCG solver only. In OpenFOAM 2.1.x the syntax is ...
Best,
Ok I will try this. But what's the problem with using PBiCG together with AMG as preconditioner? Is it a mathematical issue or just a matter of OF implementation? I thought long about it and searched for answers even more time but I didn't find any.
And another issue: you wrote I should use "GAMG" for preconditioning. Is it really the same as "AMG"? I always thought "GAMG" is just an improvement of the old "amgSolver" in OF 1.5 and "AMG" a completely new implementation.
It would be very nice for me to know the differences between all three of them. Has anyone any sources for that?
Old   February 24, 2012, 04:31
Alberto Passalacqua
The structure of the matrix is different, and the GAMG implementation only manages one type. It seems to make sense to me, since GAMG is typically used for the pressure equation.
I don't know the details of what has been implemented in -extend, since I use the Foundation release from SGI/OpenCFD.
Best,
Alberto Passalacqua
v4 & AMG warning msg more work Siemens 9 September 7, 2022 10:10
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 16:15
Problem with jet flow braennstroem OpenFOAM Running, Solving & CFD 16 May 15, 2006 03:23
