January 31, 2012, 02:20 |
simpleFoam + cyclone device. Poor result.
Andrey
Rep Power: 14 |
Hi all I am a new user to OpenFOAM and I am trying to simulate flow in a cyclone device. This device is schematically shown in the first attached image. I have poor result of the simulation with the following settings:
1. solver - simpleFoam 2. mesh - tetrahedral, ~200 000 elements (geometry - Salome, mesh - Netgen) 3. turbulence model - kEpsilon, kOmegaSST 4.boundary conditions, fvSchemes, fvSolutions, yPlusRAS.log, checkMesh.log in attach *tar.gz file. 5. wall functions disabled because y+ <1 6. I using for first 50 iterations schemes first order (Gauss upwind), for next iterations - Gauss linearUpwind SquareLeast. I also tried to use potentialFoam. Resuls of this simulation (shown in the second attached image) don't agree with the experimental setup finding (tangential velocity of the entire height of the device on average equal to 25-40 m / s). How can I improve the simulation results? Regards. |
February 1, 2012, 08:40 |
Markus Rehm
Rep Power: 17 |
you should try one of the RSM models (LaunderGibson) and improve mesh quality (maybe convert your mesh to a polyedral mesh). RSM tends to be less stable and the mesh will be more important. Start with RSM on a converged kEpsilon solution. Try limitedLinearV for velocity (similar to linearUpwind but for me it seemed to be more stable). Markus |
February 1, 2012, 13:32 |
Andrey
Rep Power: 14 |
Thanks for response
Tomorrow I will write about the results of simulations with RSM and limitedLinearV, but at the same mesh. When I use to convert "polyDualMesh -concaveMultiCells", checkMesh gives a lot of mistakes and solution doesn't converge. If I spend time creating structure mesh, I get a better result simulation? (example of the grid in attach image) |
February 1, 2012, 19:09 |
#4 | |
Arjun
Rep Power: 34 |
If this is your mesh then you need much finer mesh to get it working. Cyclones are difficult to converge and your mesh is not helping much. Stick with structured mesh but refine it further. |
March 4, 2012, 13:21 |
Andrey
Rep Power: 14 |
Sorry, I don't answer long time. I still havn't observe numerical simulation data, that are in good agreement with experiment.
Calculations are performed with structure hexa mesh (checkMesh in attach file) and turbulence model: kEpsilon, realizableKE, RNGkEpsilon, kOmegaSST, LRR, LaunderGibson. Used the following case of fvSolution and fvSchemes. fvSolution: 1. GAMG for pressure and smoothSolver with GaussSeidel for other 2. PCG for pressure and PBiCG for other fvSchemes 1. upwind for div(p, U) and other div(x,x) 2. limitedLinearV for div(p,U) and upwind for other div(x,x) 3. linearUpwindV grad(U) for div(p, U) and linearUpwind grad(U) for other (p,U) 4. limitedLinearV grad(U) for div(p,U) and gamma 0,1 for other (p, U) Boundary conditions: 1. velocity: inlet 24,694 m/s, outlet inletOutlet, wall zeroGradient 2. pressure: inlet,wall zeroGradient, outlet 0 3. k: inlet 3/2*(0,05*U_inl)=2,2867, outlet and wall zeroGradient, internalField 2,2867 4. epsilon: for outlet and wall zeroGradient, for inlet and internalField I consider two case: 4.1 epsilon=С_mu^(3/4)*k^(3/2)/l = 40,38 4.2 epsilon=k^(3/2)/(0,014*D)=1277,05 (recomendation from PhD Thesis S.Mauri: Numerical Simulation and flow analysis of an elbow diffuser) 5. R=(3/2k 0 0 3/2k 0 3/2k) = (3,43 0 0 3,43 0 3,43) for inlet and internalField, outlet and wall - zeroGradient relaxationFactors set for uniform convergence each case. 20000-40000 iterrations Modified files fvSolution and fvSchemes don't have much influence on results simulation. Figure 1 shows the tangential velocity along the radius of the cyclone device (axis on the right, plot with "first" - upwind, with "second" - other schemes). Flow field isn't physically in all cases (in experiment: maximum tangential velocity 45 m/s, and pick is locate at radius 0,03 m). Now I try numerical simulation with pisoFoam, but I think that will get the same values. Last edited by rightnow; March 4, 2012 at 13:25. Reason: attach checkMesh.tar.gz |
March 5, 2012, 07:38 |
Markus Rehm
Rep Power: 17 |
I don't really understand the velocity plot. What you could try: -Think about a velocity profile at at the inlet or make the inlet longer so that a profile can develop. -A fixed pressure at the outlet affects the profile close to it. Maybe a you should rather fix the pressure at a point close to the outlet. (See pRefValue in fvSolution). You might also send your one fvSchemes-file as example. Markus |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 07:27 |
OpenFOAM compile error | balkrishna | OpenFOAM Installation | 9 | June 17, 2011 04:53 |
Compiling OpenFOAM on hpc-fe.gbar.dtu.dk | kaergaard | OpenFOAM Installation | 1 | June 16, 2011 02:33 |
Cyclone Simulation (simpleFoam) | erncyc | OpenFOAM | 4 | January 28, 2011 10:40 |
Modelling Industrial cyclone behaviour | Gόnther Hasse | Main CFD Forum | 3 | October 12, 1999 20:34 |
