November 14, 2011, 01:42 |
rhoCentralFoam linearUpwind
Rep Power: 14 |
Dear foamers.
I want to try the schemes linearUpwind in interpolationSchemes for rhoCentralFoam solver. In the begining my fvSchemes file looks so: Code:
fluxScheme Tadmor; ddtSchemes { default Euler; } gradSchemes { default cellLimited leastSquares 1; } divSchemes { default none; div(tauMC) Gauss linearUpwind; div(phi,k) Gauss linearUpwind; div(phi,omega) Gauss linearUpwind; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; reconstruct(rho) upwind; reconstruct(U) upwind; reconstruct(T) upwind; } snGradSchemes { default corrected; } Code:
interpolationSchemes { default linear; reconstruct(rho) linearUpwind; reconstruct(U) linearUpwind; reconstruct(T) linearUpwind; } Code:
[3] --> FOAM FATAL IO ERROR: [3] Grad scheme not specified Valid grad schemes are : 8 ( Gauss cellLimited cellMDLimited extendedLeastSquares faceLimited faceMDLimited fourth leastSquares ) Code:
interpolationSchemes { default linear; reconstruct(rho) Gauss linearUpwind; reconstruct(U) Gauss linearUpwind; reconstruct(T) Gauss linearUpwind; } Code:
[17] --> FOAM FATAL IO ERROR: [17] Unknown discretisation scheme Gauss Valid schemes are : 51 ( Gamma Gamma01 MUSCL MUSCL01 Minmod OSPRE QUICK SFCD SuperBee UMIST biLinearFit blended clippedLinear cubic cubicUpwindFit downwind filteredLinear filteredLinear2 filteredLinear3 fixedBlended harmonic limitWith limitedCubic limitedCubic01 limitedGamma limitedLimitedCubic limitedLimitedLinear limitedLinear limitedLinear01 limitedMUSCL limitedVanLeer linear linearFit linearPureUpwindFit linearUpwind localBlended localMax localMin midPoint outletStabilised quadraticFit quadraticLinearFit quadraticLinearUpwindFit quadraticUpwindFit reverseLinear skewCorrected upwind vanAlbada vanLeer vanLeer01 weighted ) Thanks. |
November 14, 2011, 03:46 |
Vesselin Krastev
Rep Power: 20 |
To use the linearUpwind scheme you have to specify also a gradient scheme. The correct syntax in OF-2.0.x should be (for instance):
div(phi,k) Gauss linearUpwind grad(k); where grad(k) is the scheme specified for k in the gradSchemes section (in your case, the default cellLimited leastSquares 1 scheme will be selected). In OF-1.7.x this syntax will not be recognized, because you have to specify explicitly the gradient scheme, like in the following example: div(phi,k) Gauss linearUpwind cellLimited leastSquares 1; Finally, just a note about div(tauMC): it is an explicitly calculated divergence term, not a convective flux term, thus the only scheme that makes sense is Gauss linear. Hope this helps V. |
November 14, 2011, 10:11 |
Rep Power: 14 |
Thanks for your fast reply,
You tip has really helped me, but i have same questions: If i use Code:
interpolationSchemes { default linear; reconstruct(rho) upwind cellLimited leastSquares 1; reconstruct(U) upwind cellLimited leastSquares 1; reconstruct(T) upwind cellLimited leastSquares 1; } |
November 14, 2011, 10:30 |
#4 | |
Vesselin Krastev
Rep Power: 20 |
interpolationSchemes { default linear; reconstruct(rho) Gamma 1; reconstruct(U) GammaV 1; reconstruct(T) Gamma 1; } V. |
November 14, 2011, 10:43 |
Rep Power: 14 |
I already tried to use this:
interpolationSchemes { default linear; reconstruct(rho) Gamma 1; reconstruct(U) GammaV 1; reconstruct(T) Gamma 1; } my case has the decision only Code:
interpolationSchemes { default linear; reconstruct(rho) upwind; reconstruct(U) upwind; reconstruct(T) upwind; } Thanks. |
November 14, 2011, 10:51 |
#6 | |
Vesselin Krastev
Rep Power: 20 |
V. |
November 14, 2011, 11:02 |
Rep Power: 14 |
I solve a problem of the expiration stream (М~2-5) in vacuum what solver can you recommend? I used sonicFoam, but he required too much time for the decision.
November 14, 2011, 11:27 |
#8 | |
Vesselin Krastev
Rep Power: 20 |
V. |
November 14, 2011, 11:34 |
#9 |
Rep Power: 14 |
Thanks a lot, I will try select schemes.
A few simple questions about linearUpwind and limitedLinear | chegdan | OpenFOAM | 28 | March 30, 2024 02:44 |
rhoCentralFoam with totalPressure/totalTemperature at inlet of subsonic channel | deepblue17 | OpenFOAM Running, Solving & CFD | 5 | February 11, 2013 02:42 |
localEuler in rhoCentralFoam | praveen | OpenFOAM | 4 | October 21, 2012 02:19 |
linearUpwind scheme in OpenFOAM 2.0.1 ??? | cabul | OpenFOAM | 8 | November 9, 2011 06:57 |
Always crash when solve a C-D nozzle flow field using rhoCentralFoam | hawklion | OpenFOAM Running, Solving & CFD | 0 | March 9, 2011 06:13 |
