How to probe all points on a patch?
Like Tree2Likes
  • 2 Post By amin144
Old   August 26, 2011, 23:28
Default How to probe all points on a patch?
Tom Li
strikeraj is on a distinguished road
Hi
I am trying to run a transient flow over 3D airfoil case and I would like to record the surface pressure on the airfoil for the whole computation time frame.
However, it seems that it expects only vectors within probeLocations. Is there any way to have it probe all the points on the surface of a patch?
I tried
probeLocations
patches
WALL
but it does not work
any ideas??
Thanks a lot
strikeraj is offline   Reply With Quote
Old   August 27, 2011, 10:40
Assistant Moderator
Bernhard Gschaider
Originally Posted by strikeraj View Post
Hi
I tried
probeLocations
patches
WALL
any ideas??
Thanks a lot
What you want is a sampledSurface (type: patch). Have a look at the example dictionary that comes with the sample utility. There is also a functionObject that comes with OF that uses that mechanism
Old   September 18, 2011, 22:06
Tom Li
Hi
Thanks for your reply. But just I found out that the sample utility is for post-processing only. I am wishing to write out the pressure on a boundary surface for every time step without the need to write all variables for all time steps.
Is there an utility that can do this?
Thanks,
Tom
Old   September 19, 2011, 05:28
Assistant Moderator
Bernhard Gschaider
Hi
Thanks,
Tom
All the functionality of the sample utility exists in two functionObjects. "set" and "surface" are the names, I think
Old   September 19, 2011, 08:13
Tom Li
Hi
Thank you for you reply. I manage to get sample utility to work, just it does not work the way I thought it would.
I have a transient simulation for lets say 100k time steps. I cannot afford to save all the data for every single one. I am probably writing for every 1000 time steps. However, I need the surface pressure data for every time step on the wall boundary. I tried probing but it does not work with patch and sample utility is only a post-processing tool to extract surface data from the complete result.
Thanks,
Tom
Old   September 19, 2011, 10:45
Assistant Moderator
Bernhard Gschaider
Hi
Thanks,
Tom
The functionObjects do exactly what you want: sample the data during the run (without extra data hitting the disk)
Old   September 20, 2011, 09:54
Tom Li
Hi
Thank you for your reply. I tried searching a bit but failed to find out exactly how functionObjects work. Do you know which tutorial uses it or where I can find an explanation on how to set it up? Is it compatible with 2.0.1?
Thanks,
Tom
Old   September 20, 2011, 12:51
Assistant Moderator
Bernhard Gschaider
Hi
Thanks,
Tom
Have a look at the sloshingTank2D-tutorial. The controlDict
Old   September 20, 2011, 16:53
Tom Li
Thank you so much for your help sir. That works like a charm.
Old   April 10, 2012, 02:48
Sandy Lee
sandy is on a distinguished road
Who know what is the different use between the probe and sample?
sandy is offline   Reply With Quote
Old   April 24, 2012, 14:45
Amin Shariat KHah
amin144 is on a distinguished road
Sample write data which you want in a special location that you marked
sample write data of each step in a folder
if you have transient case, you need data in a special location during time
probe give you a file which contain data of a locations during all time steps ( you have one file for ecah point contain all time steps in probe , not many files for each time step like sample )
Goutam and Stan Zhou like this.
amin144 is offline   Reply With Quote
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 13:23
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
