Problem with Scotch in 1.7.x?
Like Tree6Likes
  • 6 Post By dancfd
Old   June 15, 2011, 22:52
Default Problem with Scotch in 1.7.x?
Daniel
dancfd is on a distinguished road
Hello all,
I have just compiled OF 1.7.x without difficulty, but ran into trouble when I tried to run my first case in parallel. Upon running decomposePar with method = scotch, I received the following error:
Create time
Time = 0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod scotch
--> FOAM FATAL ERROR:
You are trying to use scotch but do not have the scotchDecomp library loaded.
This message is from the dummy scotchDecomp stub library instead.
Please install scotch and make sure that libscotch.so is in your LD_LIBRARY_PATH.
The scotchDecomp library can then be built in $FOAM_SRC/decompositionMethods/scotchDecomp
    From function labelList scotchDecomp::decompose(const pointField&, const scalarField&)
    in file dummyScotchDecomp.C at line 193.
FOAM exiting
I am not sure how to install scotch, but I unsuccessfully tried to find the LD_LIBRARY_PATH as follows:
cd $LD_LIBRARY_PATH
bash: cd: /home/dan/OpenFOAM/ThirdParty-1.7.x/platforms/linux64Gcc/paraview-3.8.0/lib/paraview-3.8:/home/dan/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/openmpi-1.4.1:/home/dan/OpenFOAM/ThirdParty-1.7.x/platforms/linux64Gcc/openmpi-1.4.1/lib:/home/dan/OpenFOAM/dan-1.7.0/lib/linux64GccDPOpt:/home/dan/OpenFOAM/site/1.7.x/lib/linux64GccDPOpt:/home/dan/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt:/home/dan/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/dummy: No such file or directory
I just noticed that in the /lib/linux64GccDPOpt/ directory, OF 1.7.x has one less library than OF 1.7.0 - and that missing library is libscotchdecomp.so. I ran wmake libso from the /src/decompositionMethods/scotchDecomp directory, and the missing library appeared. Now it works. I hope this monologue was of use to someone.
Best,
Dan
tikulju, PolluxRV, backar and 3 others like this.
dancfd is offline   Reply With Quote
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 08:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
convergence problem Trushar Phoenics 5 August 28, 2002 00:40
