Adding a cross product source term
Like Tree1Likes
  • 1 Post By lazersos
Old   May 31, 2011, 15:18
Question Adding a cross product source term
lazersos@gmail.com
lazersos is on a distinguished road
I want to solve for 2-Fluid (ion-electron) steady state flow. Now it seems that between mhdFoam and simpleFoam this should be possible. In essence I need to add a v x B term to the simpleFoam velocity solver. My guess is this should look something like:
   fvVectorMatrix UEqn
          fvm::div(phi,U)
   eqnResidual = solve(UEqn == -fvc::grad(p)+  fvm::Sp(qi,crossProduct(Ui,B))).initialResidual();
In essence I'll want to solve this once for the ion fluid then once for the electron fluid. Then I'll calculate the current from the velocities and the modification of the field by the current. I'm also going to assume a fixed pressure profile. Any thoughts on adding a source term or experience with the forms of Sp?
lazersos is offline   Reply With Quote
Old   June 6, 2011, 12:14
Default Followup
lazersos@gmail.com
Well I got a version to compile anyway, now I just have to figure out how to set my initial condition for my solver (gradient fields, etc). Here's the code:
       volVectorField UxF;
            UxF = U ^ F;  // U x F Term
            // --- Solve for Ion Velocity
            fvVectorMatrix UiEqn
                  fvm::div(phii, U)
                + fvm::Sp(q, UxF)
            eqnResidual = solve(UiEqn == -fvc::grad(p)).initialResidual();
            maxResidual = max(eqnResidual, maxResidual);
Old   June 9, 2011, 10:44
fisch
fisch is on a distinguished road
Hello lazersos,
as far as i get it you add a source term called UxF and then you have to integrate it over the control volume.
For that you call "+fvm::Sp(q,UxF)" to integrate UxF over each cell volume, right? But what is q here?
thanks for a reply,
rupert
fisch is offline   Reply With Quote
Old   June 9, 2011, 11:24
lazersos@gmail.com
This is what I got to compile:
            UxF = U ^ F;
            fvVectorMatrix UEqn
                  fvm::div(phi, U)
                + fvm::Sp(q, UxF)
            eqnResidual = solve(UEqn == -fvc::grad(p)).initialResidual();
I believe this is the correct way to proceed as U is the quantity being varied so the implicit source term should reside in the fvVectorMatrix. The q term is just some scalar multiple in front of the source term as far as I can tell.
Kummi likes this.
How to define a transient species source term? aleisia FLUENT 3 March 7, 2011 23:58
Adding a source term to concervation of species equation bernarde STAR-CCM+ 0 June 4, 2009 04:17
Adding volumetric Source Term mohanamuraly OpenFOAM 0 May 17, 2009 23:00
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
UDF Source Term Units? Brian FLUENT 1 October 24, 2005 10:15
