Time dependent properties
Like Tree1Likes
  • 1 Post By MartinB
Old   May 2, 2011, 13:06
Default Time dependent properties
Michael Rangitsch
mrangitschdowcom is on a distinguished road
Hi all,
I need to implement a time dependent viscosity -- my fluid viscosity increases as time advances. I can't convince the viscosity models to access the run time (says runTime is out of scope). I'm not a good c++ programmer, does anyone have some guidance on how to implement something like this?
Thanks in advance!
Mike Rangitsch
mrangitschdowcom is offline   Reply With Quote
Old   May 2, 2011, 13:11
Martin
MartinB will become famous soon enough
Hi Michael,
you might have a look to my proposal in this thread:
http://www.cfd-online.com/Forums/ope...time-loop.html
There is access to the current time step...
Martin
MartinB is offline   Reply With Quote
Old   May 3, 2011, 09:13
Martin
Hi Mike,
just out of curiosity, could post your viscosity model? It just came to my mind that not the run time is the important feature for your viscosity model, but the residential time in your fluid domain... this would imply to calculate an aging process of the fluid. Since "old" fluid near an outlet would get another viscosity than "fresh" fluid from an inlet...
Martin
Old   May 9, 2011, 11:21
Default Time dependent viscosity....
Michael Rangitsch
Hi Martin,
Sorry for the delay. Unfortunately I can't share the viscosity model (customer says no). You're right, it is about the age of the fluid. The viscosity behavior changes as it ages.
I'd like one more piece of advice, though. I'd like to save the viscosity and shearRate fields during the calculations and then use the previous iterations' values to under-relax the viscosity I put into the main iteration loop. I can create a field (viscosity_old), but I can't figure out how to access it from the viscosity calculation code (again, it complains about not being in scope). I'm also not sure where to put the read/write of the viscosity values. If I do it before the PISO loop (in interFoam), at least it seems to read in the viscosity values I specify (but won't write the shearRate field), if I put it just before the runtime.Write statement it fails...
Any suggestions?
Old   May 10, 2011, 06:22
Martin
Hi Mike,
this is how I would start:
- Adding residential time as a volScalarField to interFoam. So in createFields.H you add
    // check if age exists
    switch ageExist(false);
    IOobject ageHeader
        "age",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ
    volScalarField* age;
    if (ageHeader.headerOk())
        ageExist = true;
        Info<< "Reading field age\n" << endl;
        age = new volScalarField
            IOobject
                "age",
                runTime.timeName(),
                mesh,
                IOobject::MUST_READ,
                IOobject::AUTO_WRITE
            mesh
A new field with name "age" in your time folder must be inserted, i.e. "0/age". Boundary condition for inlet is fixedValue 0, rest of the patches get zeroGradient.
A transport equation for the residential time must be solved, for example after UEqn.H:
if (ageExists)
	fvScalarMatrix ageEqn
			fvm::ddt(*age)
			+ fvm::div(phi, *age)
			- fvm::laplacian(turbulence->nuEff(), *age)
			dimensionedScalar("ageSource", *age.dimensions()*dimensionSet(0,0,-1,0,0), runTime.deltaT().value())
			//dimensionedScalar("ageSource", (*age).dimensions()*dimensionSet(0,0,-1,0,0), 1) // steady state
	ageEqn.solve();
Then derive your new viscosity model from one of the existing transportModels. Add the new coefficients to the yourNewTransportModel.H file, and read the values for them in the read() method of yourNewTransportModel.C. In the calcNu() method you have access to the time field with
    const volScalarField& residenceTime = U_.mesh().lookupObject<volScalarField>("age");
To write the fields of interest, make a new file "write.H" and call it like this
    if (runTime.outputTime())
#       include "write.H"
just before the runTime.write() call of interFoam.
The file "write.H" can look like this:
		volScalarField shearRate
				IOobject
						"shearRate",
						runTime.timeName(),
						mesh,
						IOobject::NO_READ,
				mag(fvc::grad(U))
		shearRate.write();
		volScalarField strainRate
				IOobject
						"strainRate",
						runTime.timeName(),
						mesh,
						IOobject::NO_READ,
				Foam::sqrt(2.0)*mag(symm(fvc::grad(U)))
		strainRate.write();
	volScalarField nu
			IOobject
					"nu",
					runTime.timeName(),
					mesh,
					IOobject::NO_READ,
			twoPhaseProperties.nu()
	nu.write();
Depending on your version of OpenFOAM the definition of strainRate, which is used in the transportModels for shear thinning models, varies. Therefor to verify your implementation you should check your exact definition of strainRate.
I would not do an underrelaxation of the viscosity. It doesn't seems useful for me for a PISO algorithm, it seems to be even wrong... so you don't need an viscosity_old field, I suppose.
If you do need it for some other reasons, you can define in createFields.H at the end of the file:
	volScalarField viscosity_old
			IOobject
					"visco_old",
					runTime.timeName(),
					mesh,
					IOobject::NO_READ,
and update it before calling twoPhaseProperties.correct(); in interFoam.C with
visco_old == twoPhaseProperties.nu();
Well, these hints are not tested, so use with care!
Martin
Roozbeh_Sa likes this.
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
