January 22, 2011, 18:21 |
simpleSRFoam, makePatch and cyclic patch
Rep Power: 17 |
Hi everybody.
I'm trying to set up case with simpleSRFFoam solver (OpenFOAM-1.5-dev). I based myself on the mixer tutorial in order to simulate a 4 blades marine propeller. I created a simple geometry for a test, a one single blade into a 90° wedge, so don't care if the mesh is coarse and the domain is small. I generated a mesh with Netgen and then exported in OpenFOAM-1.5+ format. The tutorial is not clear about that - maybe becouse the side periodic patched are equivalent - but I guess I must 'map' one side on the other one. If I'm right, I can use createPatch for that, but I'm experienced some errors. Does it depend on my horrible testing mesh? Isn't my boundary file correct? I attach a pic of the mesh and report my boundary file and the createPatchDict. boundary Code:
7 ( blade { type wall; nFaces 208424; startFace 3274581; } inlet { type patch;; nFaces 644; startFace 3483005; } outlet { type patch; nFaces 646; startFace 3483649; } cyclic1 { type patch; nFaces 1493; startFace 3484295; } cyclic2 { type patch; nFaces 1390; startFace 3485788; } top { type patch; nFaces 138; startFace 3487178; } hub { type wall; nFaces 30015; startFace 3487316; } ) Code:
matchTolerance 1E-3; pointSync true; patches ( { name side; type cyclic; constructFrom patches; patches (cyclic1 cyclic2); } ); Code:
Create time Reading createPatchDict. Using relative tolerance 0.001 to match up faces and points Create polyMesh for time = 0 Adding new patch side of type cyclic as patch 7 Moving faces from patch cyclic1 to patch 7 Moving faces from patch cyclic2 to patch 7 Doing topology modification to order faces. cyclicPolyPatch::getGeometricHalves : Writing half0 faces to OBJ file "/home/maurizio/OpenFOAM/maurizio-1.5-dev/run/propeller/side_half0_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 faces to OBJ file "/home/maurizio/OpenFOAM/maurizio-1.5-dev/run/propeller/side_half1_faces.obj" cyclicPolyPatch::getGeometricHalves : Writing half0 face centres to OBJ file "/home/maurizio/OpenFOAM/maurizio-1.5-dev/run/propeller/side_half0.obj" cyclicPolyPatch::getGeometricHalves : Writing half1 face centres to OBJ file "/home/maurizio/OpenFOAM/maurizio-1.5-dev/run/propeller/side_half1.obj" --> FOAM Serious Error : From function cyclicPolyPatch::getGeometricHalves(const primitivePatch&, labelList&, labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 508 Patch side gets decomposed in two zones ofinequal size: 1493 and 1390 This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp. Please adapt the featureCos setting. Continuing with incorrect face ordering from now on! face 1440 area does not match neighbour 2881 by 80.3222% -- possible face ordering problem. patch:side my area:3.6008e-05 neighbour area:1.53729e-05 matching tolerance:0.001 Mesh face:3515888 vertices:3((0.1902 -0.170322 0.170322) (0.181659 -0.168743 0.168743) (0.18614 -0.163609 0.163609)) Neighbour face:3517329 vertices:3((0.071 0.155563 0.155563) (0.066 0.155563 0.155563) (0.0687394 0.159912 0.159912)) Other errors also exist, only the largest is reported. Please rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 197. FOAM exiting After read some posts, I was in doubt about the side patches defining, so I created one single patche for both side faces. I launched simpleSRFFoam and obtain Code:
Create time Create mesh for time = 0 face 580 area does not match neighbour 1161 by 104.235% -- possible face ordering problem. patch:side my area:0.000293579 neighbour area:9.24105e-05 matching tolerance:0.001 Mesh face:871780 vertices:3((-0.302074 0.177347 0.177347) (-0.309214 0.19858 0.19858) (-0.286492 0.189158 0.189158)) Neighbour face:872361 vertices:3((0.0801642 -0.174874 0.174874) (0.080741 -0.162749 0.162749) (0.091457 -0.164054 0.164054)) Other errors also exist, only the largest is reported. Please rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 197. FOAM exiting Last edited by vaina74; January 22, 2011 at 20:19. |
January 24, 2011, 03:35 |
Rep Power: 17 |
I've just run a simple test with a meshed cube and I realized that createPatch works fine when the side faces have the same number of tet cells. If I generate a different amount of cells, it doesn't work anymore. Is this a constraint? I wonder how I can control and obtain the same number of side cells in more complex geometries.
Please, can anyone help me? |
January 26, 2011, 10:04 |
Alex
Rep Power: 16 |
If you want to create a cyclic patch from two patches, those two patches should match (within some tolerance). So if you create the mesh with some external mesh generator, be sure that the patches are linked. The number of cells should be the same, but also the relative position.
But you are using 1.5-dev, so if you cannot create a mesh with matching patches, you can always use the cyclicGgi patch type. The cyclicGgi will also work for more complicated problems, when both patches (cyclic1 and cyclic2) are full non-matching. |
January 26, 2011, 11:50 |
Rep Power: 17 |
Thanks for your reply. I already used cyclicGgi with MRFSimpleFoam solver. I'll make a test.
February 28, 2011, 05:05 |
#5 | |
Claudio
Rep Power: 16 |
I am investigating the flow through a single channel of a radial pump. So I have to use cyclicGgi (OF 1.5-dev). I ask You: Have I to use createPatch, Am I advised to do so, or what else? For the moment I do not perform this action, and the calculations seem to perform well, even if the results compared with some others are not so good. So I am worried about cyclicGgi. Thank You in advance Yours sincerely, Claudio |
February 28, 2011, 05:22 |
Alex
Rep Power: 16 |
@Claudio
I don't see the point in using createPatch. The only thing I used for cyclicGgi was faceSet and setsToZones to create the two cyclic zones from the cyclic patches. You can see a description of the use of cyclicGgi in this presentation (slide 23): http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2009/OlivierPresentation/case_study_2009_OP.pdf Best regards, Alex. |
February 28, 2011, 08:20 |
#7 | |
Claudio
Rep Power: 16 |
I have troubles when decomposing the case having cyclicGgi patches. A segmentation fault occurs? Is the a procedure to be followed to perform this task? I have already stored in the controlDict file the string "preservePatches ( Per1 );". However this error occurs anyway. Moreover, why I cannot define also a preserve patch for the other cyclic patch, named Per2? Thank You, Claudio |
February 28, 2011, 08:26 |
#8 | ||
Alex
Rep Power: 16 |
preservePatches (Per1 Per2); |
