Boundary conditions for two connected fluid region.
Like Tree1Likes
  • 1 Post By mm66
Old   October 21, 2010, 17:29
Default Boundary conditions for two connected fluid region.
hut
Anh Le
hut is on a distinguished road
I want to creat two different fluid regions with different meshes. The outlet of region 1 will connect to the inlet of region 2. Assuming the flow goes through the inlet of region 1 to outlet of region 2.
Then, the BCs for U and P should be:
-Region 1, inlet: U fixed value, P zeroGradient
- Region 2, outlet: U zeroGradient, P fixed value (0 - ambient pressure)
So, what should BCs for U and P at: Outlet of Region 1 and Inlet of Region 2 (actually, they coincide but in different meshes).
The BC patches of Outlet, region 1 and Inlet, region2 should be "regionCouple" ???
Many thanks for helping me out of this.
hut is offline   Reply With Quote
Old   December 4, 2012, 07:23
Default defining internal boundary conditions
Jamal
aujamal20 is an unknown quantity at this point
Dear
solver:chtMultiRegionFoam
version: OF-2.1.0
geometry: containing a number of fluid regions surrounded by solid regions. Its like a 2D rectangle with solid walls having inlet/outlet fluid regions and internal fluid regions.
problem: coupling solid/fluid regions in the same way as defined in tutorial but how to couple fluid/fluid regions (right now i am using zeroGradient for U,T, p) and solid/solid regions.
And as I use to run the simulation, after some iterations temperature goes to very high values.
Thanks
Jamal
aujamal20 is offline   Reply With Quote
Old   December 5, 2012, 01:07
Hanzo is on a distinguished road
Hey Jamal and Anh,
have a look at
http://www.cfd-online.com/Forums/ope...tml#post395838
Linse, ZKW and me are working on the same issue.
Hanzo is offline   Reply With Quote
Old   June 20, 2019, 17:45
Default Two touching fluids for heat transfer in OpenFOAM
mm66 is on a distinguished road
Hi there,
Sorry for reactivating this dormant thread. I have a very basic question! I know that in many CFD software two fluids should be separated by a solid unless they form a mixture (i.e. VOF). This is not the case in my simulation.
I want to simulate heat transfer using chtMultiRegionSimpleFoam between two fluids. The geometry is similar to a double pipe heat exchanger. Since OpenFOAM is inherently different from many other solvers, I was thinking whether it is possible to couple the two fluids directly (without simulating the sandwiched solid between them). If yes, what should be assigned in the shared boundaries?
I tried some cases but am getting divergence after few iterations (negative temperature)
Thanks a million in advance...
kraf likes this.
mm66 is offline   Reply With Quote
Courant no%23 and sharp corner in 3D jam OpenFOAM Running, Solving & CFD 6 November 18, 2008 09:21
Boundary conditions at Fluid Solid interface (CHT) michelle CFX 1 April 21, 2008 05:06
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
