rho euation in rhoPisoFoam
Like Tree9Likes
  • 8 Post By alberto
  • 1 Post By alberto
Old   October 2, 2010, 12:48
Default rho euation in rhoPisoFoam
Nilesh Rane
nileshjrane is on a distinguished road
In rhoPisoFoam, the .c code includes rhoEqn.H file but the file is not in that folder. Is is getting included from some other common directory?? I am asking this because when i solve my simulation the rho equation is not getting solved, it seems.
Can anyone tell me, what is the problem here?? Why the rho equation is not being solved??
Starting time loop
Courant Number mean: 0.00160209 max: 0.237358
Time = 1e-06
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.11628e-11, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.98311e-11, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.87167e-09, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 3.93336e-13, No Iterations 2
DICPCG: Solving for p, Initial residual = 1, Final residual = 1.85699e-09, No Iterations 12
DICPCG: Solving for p, Initial residual = 8.61972e-05, Final residual = 2.87593e-10, No Iterations 2
DICPCG: Solving for p, Initial residual = 6.9308e-06, Final residual = 6.70903e-11, No Iterations 2
time step continuity errors : sum local = 2.47432e-14, global = -1.96566e-15, cumulative = -1.96566e-15
DILUPBiCG: Solving for h, Initial residual = 0.464004, Final residual = 4.19598e-09, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0986332, Final residual = 8.95905e-09, No Iterations 10
DICPCG: Solving for p, Initial residual = 2.74445e-05, Final residual = 9.04744e-10, No Iterations 2
DICPCG: Solving for p, Initial residual = 4.60957e-06, Final residual = 7.9637e-09, No Iterations 1
time step continuity errors : sum local = 3.76913e-12, global = -3.46891e-13, cumulative = -3.48856e-13
DILUPBiCG: Solving for h, Initial residual = 0.105746, Final residual = 5.79122e-10, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0235514, Final residual = 5.9246e-09, No Iterations 9
DICPCG: Solving for p, Initial residual = 1.34825e-05, Final residual = 4.20418e-10, No Iterations 2
DICPCG: Solving for p, Initial residual = 4.14208e-06, Final residual = 7.32319e-09, No Iterations 1
time step continuity errors : sum local = 3.68586e-12, global = -2.74195e-13, cumulative = -6.23051e-13
DILUPBiCG: Solving for h, Initial residual = 0.0263855, Final residual = 1.16006e-10, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.00641807, Final residual = 4.27544e-09, No Iterations 8
DICPCG: Solving for p, Initial residual = 5.14856e-06, Final residual = 6.37387e-09, No Iterations 1
DICPCG: Solving for p, Initial residual = 2.17279e-06, Final residual = 4.27578e-09, No Iterations 1
time step continuity errors : sum local = 2.18805e-12, global = -1.21706e-13, cumulative = -7.44757e-13
Imagination is more important than knowledge..
nileshjrane is offline   Reply With Quote
Old   October 3, 2010, 22:06
Alberto Passalacqua
Search your OpenFOAM-1.7.x/src directory for rhoEqn.H and you will find it. It is basically
solve(fvm::ddt(rho) + fvc::div(phi));
with explicit discretization of the divergence to avoid conservation errors.
The fact you see residuals equal to zero means that the solution is exact, not that the equation is not solved. You are using the diagonal solver, which is direct, and gives you the exact solution of the linear system.
Best,
Alberto Passalacqua
Old   October 4, 2010, 07:07
Nilesh Rane
But No of iterations is also 0.
Old   October 4, 2010, 13:02
Alberto Passalacqua
This is really basic
How many iterations do you need to obtain the exact solution of a linear system with a direct solver? The answer is zero, because the method is not iterative
You basically can easily do that with the Thomas algorithm for whatever tri-diagonal system (or block tri-diagonal). Check a book on the topic to have the details.
Best,
ashish.vinayak likes this.
Alberto Passalacqua
Old   October 5, 2010, 08:44
Lightbulb
Nilesh Rane
Ohh...OF takes it in that sense. I was thinking on different line. I thought if you solve an equation (or rather a system of equations in turn) 1 time then No of Iterations should be 1 and so on...
I do know about TDMA.. have used it in my UG assignments..
Thanks a lot..
How to define and calculate LES variables rhoPisoFoam Jotazeld OpenFOAM 1 April 3, 2020 05:12
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 14:38
rhoPisoFoam stability problems at low Mach ivan_cozza OpenFOAM 1 October 1, 2010 12:03
help: rhoPisoFoam to compressibleInterFoam jason.ryon OpenFOAM 0 March 8, 2010 13:45
Error log vw.cfd OpenFOAM 6 August 7, 2009 06:44
