Oscillating cylinder using icoFoam blowing up
Like Tree1Likes
  • 1 Post By rieuk
Old   September 21, 2010, 08:40
Default Oscillating cylinder using icoFoam blowing up
Pavan
rieuk is on a distinguished road
Hey guys I'm simulating a (2D) transversely oscillating cylinder using a non-inertial reference frame using the following modification to icoFoam:
scalar Pi = mathematicalConstant::pi;
dimensionedScalar accCt("accCt",dimensionSet(0,1,-2,0,0,0,0),-3.0*pow(2.0*Pi/3.0,2)*Foam::cos(2.0*Pi*runTime.value()/3.0));
dimensionedVector acc("acc",dimensionSet(0,1,-2,0,0,0,0), vector::zero);
acc.component(vector::Y) = accCt;
        fvVectorMatrix UEqn
            fvm::ddt(U)
          + fvm::div(phi, U)
          - fvm::laplacian(nu, U)
       acc
        solve(UEqn ==  - fvc::grad(p));
However the run keeps blowing up (Floating Point Exception with ridiculously high velocity magnitude) at around the same time even for very small delta T... can anyone see what's wrong with my implementation?
utkunun likes this.
rieuk is offline   Reply With Quote
Old   September 22, 2010, 06:02
Pavan
Hmm does my acc term need to be scaled by density of the fluid?...
Old   September 22, 2010, 10:22
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi
I hope you are doing very well.
I am not sure that your solver is true. But may I ask you how implement geometry and boundary conditions?
Best regards
Good luck
Ata
ata is offline   Reply With Quote
Old   September 22, 2010, 10:25
Pavan
What do you mean you're not sure, as in you think it's wrong? Well with velocity boundary conditions I intend to use dirichlet conditions (freestream + sinusoidal cylinder velocity component) for inlet and top/bottom and zero gradient for outlet. I'm thinking groovyBC is the only way to handle that but for now I'm just using fixedValue to see if the solver is doing what it's supposed to. Right now it's just doing crazy things like creating random vortices emanating from the boundaries...
Old   September 22, 2010, 10:32
ata
ata's Avatar
ata kamyabi
no no no no
Excuse me. I do not mean your code is incorrect. At least in my knowledge.
I think may be your BCs are bad.
good luck
Old   September 22, 2010, 12:25
Pavan
What's wrong with them?
tutorial for solving oscillating cylinder problem CH FLUENT 8 April 2, 2014 11:56
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 06:49
problem with oscillating cylinder ammi FLUENT 0 December 18, 2006 05:06
problem with oscillating cylinder zonexo FLUENT 3 September 14, 2006 11:13
UDF for oscillating cylinder fredD FLUENT 0 July 16, 2004 10:32
