transient Simulation with porous media
Like Tree1Likes
  • 1 Post By Chrisi1984
Old   September 6, 2010, 05:45
Default transient Simulation with porous media
Chrisi1984 is on a distinguished road
is there a transient solver which can model porous medias in OpenFOAM ?
Also there is a file "porousZones" in folder constant of the tutorial for the solver rhoPimpleFoam (OF 1.6), for me it seems as if the solver would not include the darcy law, right?
Can some one give me advise how to implement the darcy law like it is done in rhoPorousSimpleFoam (implicit).
Are anywhere still existing some transient solvers for porous media?
Best ragards Chrisi
Chrisi1984 is offline   Reply With Quote
Old   September 6, 2010, 08:08
I solved my problem.
I discovered that in OF 1.7 there is a transient solver for porous medias named rhoPorousMRFPimpleFoam.
Perhabs it helps someone.
Regards Chrisi
Bahram likes this.
Old   June 20, 2011, 10:31
Cecily
Black-Pearl is on a distinguished road
Hello, are you coming along well with the Solver?
I have many Problems.
Black-Pearl is offline   Reply With Quote
Old   December 2, 2012, 21:40
Default thanks
zqq
zqq
zqq is on a distinguished road
I always search for a transient solver of porosity,it helps me,thanks
zqq is offline   Reply With Quote
Old   August 26, 2015, 10:34
Question
a.b.mkarzel
adrianabm is on a distinguished road
hello,
i'm new to OpenFOAM and am currently using version 2.4, do you know if there would be an equivalent solver to the one you mentioned in the new version ? (I can't seem to find rhoPorousMRFPimpleFoam)
thanks
adrianabm is offline   Reply With Quote
Old   August 26, 2015, 16:13
M. C.
student666 is on a distinguished road
Hi adriana,
you can use pimpleFoam, simpleFoam, or whatever and by adding fvOptions dict into system directory you can add a porous zone.
Google fvOptions.
Bye
student666 is offline   Reply With Quote
Old   August 26, 2015, 17:13
a.b.mkarzel
hello,
I am currently using porousSimpleFoam and adding a porous zone by using the commands
setSet -> cellSet -> cellZoneSet (and i haven't found a way yet to verify if indeed the porous zone is implemented correctly or not) but I was curious because I am looking for a way to solve the flow through a porous medium by using a transient solver instead of the steady state one...
and I'm not sure that if I simply set "Euler" or another method in the ddt scheme "key" in fvScheme, it would switch from steady state to transient (?)... I'm pretty sure it's not that simple..
So from your comment I understand that I can use any solver as long as I combine it with the correct definition of a porous zone in fvOptions, it should work ?
anyway, thanks for your message, i'll look into it tomorrow
flow thru porous media, PLEASE HELP Goker FLUENT 4 September 8, 2012 05:02
DPM on porous media magnounibo FLUENT 0 April 23, 2009 07:35
Testing the integrity of POROUS media and por jump Azman FLUENT 0 July 31, 2006 12:11
Three-Phase Simulation Through Porous Media Sanjib FLUENT 0 July 17, 2005 13:49
Porous media and convergence A.Joshi FLUENT 0 October 21, 2003 23:09
