transsonic nozzle with rhoSimpleFoam
Like Tree1Likes
  • 1 Post By Unseen
Old   August 24, 2010, 09:50
Default transsonic nozzle with rhoSimpleFoam
Basti E
Unseen is on a distinguished road
Hi, I am trying to simulate a transsonic nozzle (like a laval nozzle with a convergent and a divergent part) using the rhoSimpleFoam solver. The case is set up to use the SST turbulence modell.
Boundary conditions are as follows:
At the inlet I specify T_0 and p_0, and at the outlet I set a static pressure and temperature to zeroGradient. Now the pressure ratio p_static/p_0 determines how the flow through the nozzle will look like: completely subsonic, transsonic or completely supersonic in the divergent part.
This setup works fine for CFX and sonicFoam, but for comparitive reasons I want to simulate this with rhoSimpleFoam too. Actually I even think it would make more sense using rhoSimpleFoam instead of sonicFoam since I want to find a steady solution. But I can't get it to work.
Here is the output from rhoSimpleFoam:
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 7.50557e-08, No Iterations 6
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 2.77255e-07, No Iterations 5
DILUPBiCG: Solving for h, Initial residual = 0.482888, Final residual = 5.27538e-08, No Iterations 3
DICPCG: Solving for p, Initial residual = 1, Final residual = 9.90481e-07, No Iterations 412
DICPCG: Solving for p, Initial residual = 0.00200474, Final residual = 9.53918e-07, No Iterations 301
DICPCG: Solving for p, Initial residual = 0.000147977, Final residual = 9.80301e-07, No Iterations 335
DICPCG: Solving for p, Initial residual = 7.0753e-05, Final residual = 9.78237e-07, No Iterations 183
DICPCG: Solving for p, Initial residual = 1.43311e-05, Final residual = 9.54748e-07, No Iterations 300
DICPCG: Solving for p, Initial residual = 6.37506e-06, Final residual = 9.87798e-07, No Iterations 37
time step continuity errors : sum local = 0.378442, global = -0.00107449, cumulative = -0.00107449
rho max/min : 1.15862 0.616445
smoothSolver: Solving for omega, Initial residual = 0.466632, Final residual = 9.60914e-05, No Iterations 10
bounding omega, min: -4.70953e+07 max: 5.36335e+08 average: 2.42753e+06
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.09971e-07, No Iterations 4
bounding k, min: 0 max: 2045.21 average: 174.164
ExecutionTime = 3.98 s ClockTime = 4 s
Time = 2
DILUPBiCG: Solving for Ux, Initial residual = 0.19459, Final residual = 2.09254e-07, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.0855989, Final residual = 1.10864e-08, No Iterations 5
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 8.97303e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.957095, Final residual = 9.74092e-07, No Iterations 517
DICPCG: Solving for p, Initial residual = 0.0135551, Final residual = 9.30689e-07, No Iterations 442
DICPCG: Solving for p, Initial residual = 0.00064559, Final residual = 9.22921e-07, No Iterations 410
DICPCG: Solving for p, Initial residual = 0.000819135, Final residual = 9.92676e-07, No Iterations 246
DICPCG: Solving for p, Initial residual = 0.00010276, Final residual = 9.41144e-07, No Iterations 285
DICPCG: Solving for p, Initial residual = 0.000100948, Final residual = 9.60549e-07, No Iterations 206
time step continuity errors : sum local = 0.396817, global = -0.0229595, cumulative = -0.024034
rho max/min : 1.15876 1e-06
smoothSolver: Solving for omega, Initial residual = 0.00310563, Final residual = 2.19338e-07, No Iterations 10
bounding omega, min: -6.69351e+11 max: 8.60937e+13 average: 8.01497e+11
DILUPBiCG: Solving for k, Initial residual = 0.179666, Final residual = 2.05165e-08, No Iterations 5
bounding k, min: 0 max: 3073.3 average: 168.747
ExecutionTime = 8.13 s ClockTime = 8 s
Time = 3
DILUPBiCG: Solving for Ux, Initial residual = 0.152395, Final residual = 4.46597e-07, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.0544148, Final residual = 1.16204e-07, No Iterations 4
DILUPBiCG: Solving for h, Initial residual = 0.56658, Final residual = 2.33144e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.251858, Final residual = 7.38651e-07, No Iterations 384
DICPCG: Solving for p, Initial residual = 4.20666e-05, Final residual = 9.08749e-07, No Iterations 28
DICPCG: Solving for p, Initial residual = 7.88155e-06, Final residual = 6.59651e-07, No Iterations 21
DICPCG: Solving for p, Initial residual = 2.55826e-06, Final residual = 9.73543e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 1.23148e-06, Final residual = 7.47417e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 7.42068e-07, Final residual = 7.42068e-07, No Iterations 0
time step continuity errors : sum local = 1.55563, global = 0.0208779, cumulative = -0.00315611
rho max/min : 2 1e-06
smoothSolver: Solving for omega, Initial residual = 0.585117, Final residual = 3.521e-09, No Iterations 5
DILUPBiCG: Solving for k, Initial residual = 0.25674, Final residual = 9.63173e-07, No Iterations 1
bounding k, min: -0.0701715 max: 4987.9 average: 162.727
ExecutionTime = 9.32 s ClockTime = 10 s
Time = 4
DILUPBiCG: Solving for Ux, Initial residual = 0.997795, Final residual = 1.64032e-07, No Iterations 6
DILUPBiCG: Solving for Uy, Initial residual = 0.998882, Final residual = 7.32716e-07, No Iterations 5
DILUPBiCG: Solving for h, Initial residual = 0.0744124, Final residual = 4.70478e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.759872, Final residual = 9.57541e-07, No Iterations 284
DICPCG: Solving for p, Initial residual = 0.000123465, Final residual = 9.82243e-07, No Iterations 57
DICPCG: Solving for p, Initial residual = 8.70489e-06, Final residual = 9.71241e-07, No Iterations 4
DICPCG: Solving for p, Initial residual = 1.76624e-06, Final residual = 5.50452e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 7.16095e-07, Final residual = 7.16095e-07, No Iterations 0
time step continuity errors : sum local = 404.096, global = -19.2919, cumulative = -19.2951
smoothSolver: Solving for omega, Initial residual = 0.788337, Final residual = 1.3774e-06, No Iterations 10
bounding omega, min: -2.96432e+14 max: 3.00319e+16 average: 3.21144e+12
DILUPBiCG: Solving for k, Initial residual = 0.968773, Final residual = 2.01015e-09, No Iterations 1
bounding k, min: -756.427 max: 35883.4 average: 195.582
ExecutionTime = 10.39 s ClockTime = 11 s
Time = 5
DILUPBiCG: Solving for Ux, Initial residual = 0.310195, Final residual = 1.73164e-07, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.126598, Final residual = 5.89545e-07, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.680939, Final residual = 3.04399e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.998137, Final residual = 9.43214e-07, No Iterations 487
DICPCG: Solving for p, Initial residual = 4.64363e-05, Final residual = 9.30679e-07, No Iterations 4
DICPCG: Solving for p, Initial residual = 6.05651e-06, Final residual = 9.73192e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 2.56727e-06, Final residual = 6.63206e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 1.3765e-06, Final residual = 4.99567e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 7.74991e-07, Final residual = 7.74991e-07, No Iterations 0
time step continuity errors : sum local = 897588, global = -74572.2, cumulative = -74591.5
smoothSolver: Solving for omega, Initial residual = 0.533712, Final residual = 0.000103851, No Iterations 5
bounding omega, min: -1.622e+16 max: 1.41955e+17 average: 3.58821e+13
DILUPBiCG: Solving for k, Initial residual = 0.661468, Final residual = 2.9169e-07, No Iterations 1
bounding k, min: -153.288 max: 42609.5 average: 318.405
ExecutionTime = 11.58 s ClockTime = 12 s
Time = 6
DILUPBiCG: Solving for Ux, Initial residual = 0.213536, Final residual = 9.55407e-07, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 0.126084, Final residual = 4.68714e-07, No Iterations 3
DILUPBiCG: Solving for h, Initial residual = 0.221702, Final residual = 4.57775e-08, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.962782, Final residual = 8.92019e-07, No Iterations 530
DICPCG: Solving for p, Initial residual = 0.00113766, Final residual = 9.72405e-07, No Iterations 21
DICPCG: Solving for p, Initial residual = 0.000189473, Final residual = 8.29085e-07, No Iterations 8
DICPCG: Solving for p, Initial residual = 6.06308e-05, Final residual = 9.18088e-07, No Iterations 7
DICPCG: Solving for p, Initial residual = 1.00251e-05, Final residual = 9.88796e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 3.73146e-06, Final residual = 9.7275e-07, No Iterations 2
time step continuity errors : sum local = 2.79573e+07, global = 10554.4, cumulative = -64037
smoothSolver: Solving for omega, Initial residual = 0.999496, Final residual = 1.11391e-10, No Iterations 5
bounding omega, min: -4.95025e+17 max: 1.19663e+24 average: 4.05024e+19
DILUPBiCG: Solving for k, Initial residual = 0.604858, Final residual = 7.6708e-12, No Iterations 1
bounding k, min: -1213.68 max: 52183.5 average: 196.438
ExecutionTime = 12.96 s ClockTime = 13 s
Time = 7
DILUPBiCG: Solving for Ux, Initial residual = 0.143333, Final residual = 1.78302e-08, No Iterations 5
DILUPBiCG: Solving for Uy, Initial residual = 0.367181, Final residual = 8.26728e-08, No Iterations 5
DILUPBiCG: Solving for h, Initial residual = 0.345348, Final residual = 3.69898e-08, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.7791, Final residual = 9.83852e-07, No Iterations 585
DICPCG: Solving for p, Initial residual = 0.00667543, Final residual = 9.142e-07, No Iterations 550
DICPCG: Solving for p, Initial residual = 0.00206138, Final residual = 8.97629e-07, No Iterations 531
DICPCG: Solving for p, Initial residual = 0.000466277, Final residual = 9.62494e-07, No Iterations 283
DICPCG: Solving for p, Initial residual = 0.000308349, Final residual = 9.64406e-07, No Iterations 197
DICPCG: Solving for p, Initial residual = 0.000185042, Final residual = 9.61781e-07, No Iterations 195
time step continuity errors : sum local = 9.87003e+07, global = -4.30657e+06, cumulative = -4.37061e+06
smoothSolver: Solving for omega, Initial residual = 0.538495, Final residual = 9.77628e-11, No Iterations 5
bounding omega, min: -2.19937e+22 max: 3.5899e+23 average: 1.57063e+19
DILUPBiCG: Solving for k, Initial residual = 0.229398, Final residual = 1.61737e-07, No Iterations 2
bounding k, min: -191.332 max: 48987.5 average: 164.447
ExecutionTime = 17.4 s ClockTime = 18 s
Time = 8
DILUPBiCG: Solving for Ux, Initial residual = 0.182003, Final residual = 3.63321e-07, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.259147, Final residual = 3.8712e-08, No Iterations 5
DILUPBiCG: Solving for h, Initial residual = 0.98536, Final residual = 3.79371e-07, No Iterations 3
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/unseen/OpenFOAM/OpenFOAM-1.7.x/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 61.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/unseen/OpenFOAM/OpenFOAM-1.7.x/lib/linux64IccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/unseen/OpenFOAM/OpenFOAM-1.7.x/lib/linux64IccDPOpt/libOpenFOAM.so"
#2 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/home/unseen/OpenFOAM/OpenFOAM-1.7.x/lib/linux64IccDPOpt/libbasicThermophysicalModels.so"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/home/unseen/OpenFOAM/OpenFOAM-1.7.x/lib/linux64IccDPOpt/libbasicThermophysicalModels.so"
in "/home/unseen/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64IccDPOpt/rhoSimpleFoam"
#5 __libc_start_main in "/lib/libc.so.6"
Aborted
There are several things which are going wrong here:
1.) bounding omega, min: -4.70953e+07 max: 5.36335e+08 average: 2.42753e+06
omega is not supposed to become negative at any time!
2.) bounding k, min: -0.0701715 max: 4987.9 average: 162.727
same for k, it is not allowed to become negative!
3.) huge continuity errors
4.) when I look at the produced results during these few timesteps the pressure gets massive negative values (-1e1 0Pa region).
So obviuosly I am doing something wrong. I just can't figure out what it is ...
I haven't changed anything from the setup except adding the SIMPLE dictionary to the fvSolution and changing e to h when going from sonicFoam to rhoSimpleFoam.
Any help would be greatly appreciated, thank you
hogsonik likes this.
Unseen is offline   Reply With Quote
Old   August 24, 2010, 13:06
Thumbs up
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
hi Basti
there is a problem in setting the initial guess values or may be with boundary conditions or even it may be with grading part of the mesh at the inlet.
so explain these things in detail or share your files. so that you may get some help for solving your problem.
you said this setup had worked with sonicFoam solver (did you compare the results). will you tell me which version of OpenFOAM you are using.
kiran is offline   Reply With Quote
Old   August 24, 2010, 16:29
Basti E
sry I forgot some info, you are right I should post some more
So, I am using OF 1.7.x updated today.
Here are boundary and initial settings:
Its a 2D mesh. It represents half of the problem since it is a symmetric problem.
p:
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1.0e5;
boundaryField
in
type totalPressure;
gamma 1.4;
p0 uniform 1.0e5;
out
type fixedValue;
value uniform 0.55e5;
topwall
type zeroGradient;
left
type empty;
symmaxis
type symmetryPlane;
right
type empty;
U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform ( 0 0 0 );
boundaryField
in
type zeroGradient;
out
type zeroGradient;
topwall
type fixedValue;
value uniform (0 0 0);
left
type empty;
symmaxis
type symmetryPlane
right
type empty;
T:
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
in
type totalTemperature;
U U;
phi phi;
rho none;
psi psi;
gamma 1.4;
T0 uniform 300;
out
type zeroGradient;
topwall
type zeroGradient;
left
type empty;
symmaxis
type symmetryPlane;
right
type empty;
omega:
dimensions [0 0 -1 0 0 0 0];
internalField uniform 1e6;
boundaryField
in
type zeroGradient;
out
type zeroGradient;
topwall
type compressible:megaWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
beta1 0.075;
value uniform 1e6;
left
type empty;
symmaxis
type symmetryPlane;
right
type empty;
k:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 250;
boundaryField
in
type fixedValue;
value uniform 0;
out
type inletOutlet;
inletValue uniform 0;
value uniform 0;
topwall
type compressible::kqRWallFunction;
value uniform 250;
left
type empty;
symmaxis
type symmetryPlane;
right
type empty;
mut:
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 0;
boundaryField
in
type calculated;
value uniform 0;
out
type calculated;
value uniform 0;
topwall
type mutWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
left
type empty;
symmaxis
type symmetryPlane
right
type empty;
alphat:
boundaryField
in
type calculated;
value uniform 0;
out
type calculated;
value uniform 0;
topwall
type alphatWallFunction;
Prt 0.85;
value uniform 0;
left
type empty;
symmaxis
type symmetryPlane
right
type empty;
If there is more I forgot I will post it
Old   August 24, 2010, 20:53
kiran Ambilpur
hi
its better to attach your files.
i found mistakes you are giving pressure inlet and pressure outlet
and zerogradient for inlet and outlet velocities.
why k and omega are zero at inlet.
please upload your files.
Old   August 25, 2010, 05:34
Basti E
Hm, why is it a mistake to specify the total pressure at the inlet and the static pressure at the outlet? ... Based on the pressure difference between inlet and outlet there has to develop a flow with initially unknown velocities at inlet and outlet. Is there any other way to set this up WITHOUT specifying a velocity at inlet and outlet, since I don't know these yet?
Old   August 26, 2010, 11:30
kiran Ambilpur
we all know that any fluid flows from high pressure region to low pressure region.
but when we specifying the boundary condition for a subsonic problem
we should specify it as velocity inlet and a presure outlet (since there is a characteristic line(in fact there are two but one travels inside) travelling inward to the nozzle so it should be given as pressure oulet). refer CFD book by John.D.Anderson. Jr
so define velocity at inlet and pressure(static) at oulet. And give some initial values at inlet for K , Omega
hope this solves your problem
are you validating this problem.
you said you have tried with sonicFoam.
would you share that results.
Old   August 27, 2010, 08:23
Default Same issue
Nilesh Rane
nileshjrane is on a distinguished road
Hello all,
I am also facing same issue. i am using rhoPisoFoam and k-epsilon model. After some iterations the values of P, k, eps blow up to so hign numbers and the error is shown below.
rho max/min : 5.89446 3.44454
bounding p, min: -5.61732e+06 max: 4.05538e+06 average: 999735
DILUPBiCG: Solving for epsilon, Initial residual = 0.9528, Final residual = 9.15234e-06, No Iterations 6
bounding epsilon, min: -103372 max: 8.67646e+06 average: 2933.08
DILUPBiCG: Solving for k, Initial residual = 0.11952, Final residual = 5.59631e-06, No Iterations 5
DILUPBiCG: Solving for Ux, Initial residual = 0.517388, Final residual = 0.0209456, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.50828, Final residual = 0.042113, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.52129, Final residual = 0.0342811, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.796855, Final residual = 0.0200661, No Iterations 3
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::calculate() in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::correct() in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
in "/opt/openfoam170/applications/bin/linux64GccDPOpt/rhoPimpleFoam"
#6 __libc_start_main in "/lib/libc.so.6"
Floating point exception
its similar to what Basti is getting.
I am also giving same kind of BCs as Kiran has alredy suggested, still the error is not getting solved..
I have tried evry possible BC specification methods. But no luck..
PFA my case files, mesh is not there as its 'engrid' mesh and too large to post here.
Imagination is more important than knowledge..
nileshjrane is offline   Reply With Quote
Old   April 16, 2014, 04:38
adarsh tiwari's Avatar
adarsh tiwari
adarsh tiwari is on a distinguished road
Hi all,
As you already know that rhoSimpleFoam is a steady-state solver, while, somebody is getting results from rhoSonicFoam and rhoPisoFoam.
I think you must give a try with rhoPimpleFoam with reduced time steps. This thing worked fine for me in a particular case.
Further you can validate the results with your theoretical calculations or some empirical considerations.
Thanks and Regards,
Adarsh Tiwari
adarsh tiwari is offline   Reply With Quote
Old   July 1, 2022, 07:54
Oliver Meng is on a distinguished road
what about a supersonic problem? Which kind of inlet boudary woudl be better?
Oliver Meng is offline   Reply With Quote
Convergent Divergent Nozzle Hrishikesh Main CFD Forum 12 June 25, 2016 03:06
Nozzle Flow - Divergence Problem Ijaz FLUENT 9 January 11, 2014 05:36
C-D nozzle supersonic jet boundary Gland FLUENT 4 May 24, 2012 01:25
calculate nozzle length oe Main CFD Forum 0 July 30, 2008 15:06
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
