pressure in incompressible solvers e.g. simpleFoam
Like Tree2Likes
  • 1 Post By Bjw
  • 1 Post By piu58
Old   August 23, 2010, 09:45
Default pressure in incompressible solvers e.g. simpleFoam
Christian Graurock
chrizzl is on a distinguished road
Dear All,
I have a general question about the setup of the pressure in an incompressible solver like the simpleFoam-solver.
As we all know in simpleFoam the "strange" pressure units are a result of the partition by the density. This is reasonable, because the density will not change in an incompressible flow. Hence the only property of the fluid which can be changed by the user is the kinematic viscosity.
In my opinion in a pressure driven flow (pressure difference between inlet and outlet are known from an experiment) you have to normalise the fixed pressure values at inlet and outlet by the density.
In common commercial flow solvers you have to define a reference density. That is not possible in simpleFoam and why I wrote down my thoughts in this forum. It would be gald if someone could help me in this open discussion.
Regards,
Christian
chrizzl is offline   Reply With Quote
Old   August 24, 2010, 04:23
Christian Graurock
Another reason for posting this massage is, that I have seen many users who don't care about the normalization of the pressure. I just want to make it clear (for me) in this forum.
There are experimental data like:
Inlet: 1,013,250 Pa
Outlet: 101,325 Pa
--> Delta p: 911,925 Pa
With a density of air round about 1,2 kg/m³ you've got:
Inlet: 844,375 m²/s²
Outlet: 84,437.5 m²/s²
--> Delta p: 759,937.5 m²/s²
Which setup is the correct one? In my opinion it's the second one
Thanks,
Christian
Old   August 24, 2010, 06:41
Bjw
Björn Westendorf
Bjw is on a distinguished road
Changing the scale and/or the unit of pressure should not change the physics of your problem.
Bjw is offline   Reply With Quote
Old   August 24, 2010, 07:02
kjetil is on a distinguished road
Well, you could just have a look at the units atop in the p-file. From there it should be very clear if your normalization is correct.
kjetil is offline   Reply With Quote
Old   August 24, 2010, 07:07
Christian Graurock
Thank you for your reply.
I know, that the physics are the same, but the first setup only make sense in a compressible simulation, the second one in an incompressible simulation.
If you set your pressure difference, which is known from an experiment without density-normalization to your simpleFoam-setup you will get a setup, which is different to the experiment (factor in this case 1.2).
--> The setup does not mirror your experiment. Is this correct?
From your reply I guess, that my thoughts are correct. Thanks a lot.
Old   August 24, 2010, 09:08
Sven Degner
sven82 is on a distinguished road
Hi everyone,
I'm with Cristian, was your experimental data's initialization with a pressure difference,
you must dived the pressure through the density ("for a normalization"). After this the results should look like the experimental data's. A other opportunity is the work with a post processor.
best regards
Sven
sven82 is offline   Reply With Quote
Old   August 24, 2010, 09:41
Bjw
Björn Westendorf
Christian, sorry that I misunderstood your Question.
Yes, absolutely. You must divide the pressure (Unit Pa) by density first when using an incompressible solver.
EddySouth likes this.
Old   August 24, 2010, 12:19
Christian Graurock
Thanks, that's exactly what I was looking for.
Old   April 8, 2016, 04:47
Prasanna Welahettige
prasa is on a distinguished road
Originally Posted by chrizzl View Post
Dear All,
Regards,
Christian
I was reading this thread these days. And I found this will help to future readers. Like to add a comment.
In simplefoam continuity equation doesn't include the density because incompressible fluid. But in momentum equation density is a parameter(constant). Therefore pressure has introduced as pressure/density.
units [pressure/density] = m2/s3
cheers.
prasa is offline   Reply With Quote
Old   June 9, 2016, 12:01
Jan Brunner is on a distinguished road
Hi Prasa
Thanks for wanting to clarify this but the unit should be m2/s2, right?
All the best,
Jan
Jan Brunner is offline   Reply With Quote
Old   June 9, 2016, 13:30
Originally Posted by Jan Brunner View Post
Hi Prasa
All the best,
Jan
Hi Jan,
Yes it should be m2/s2.
Regards,
Prasa.
Old   March 27, 2017, 10:42
Default For Hydrogen ??
  #12
cfdRocker
Manojmech is on a distinguished road
Sorry for reopening this thread.
I would like to know if the fluid is hydrogen. Density of Hydrogen is very less compared to Air. its around 0.0899 kg/m3 and Inlet pressure shoots up and I am getting divergence in simpleFoam.
Can anyone clarify this ??
Regards,
Manoj
Manojmech is offline   Reply With Quote
Old   March 27, 2017, 12:49
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Dear Manoj,
you get stabilisation problems not for the density but for the much larger Renolds number which results from it. It is well known that larger Re numbers may arise destabilisation. But can be solved, of course. It depends on the solver you use, which arrangements are possible. in simpleFoam you may chose a lesser value for relaxationFactors in fvSolution.
Teresa.Z likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 28, 2017, 06:49
cfdRocker
Hello Uwe Pilz,
Thank you for your response. I tried reducing the relaxationFactors as low as 0.1 for U but did not work .
My simulation residuals are as below :-
Create mesh for time = 0
SIMPLE: convergence criteria
field p tolerance 1e-06
field U tolerance 1e-06
field "(k|epsilon|omega|f|v2)" tolerance 1e-06
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
No MRF models present
No finite volume options present
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.00189998, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.00172237, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0025047, No Iterations 1
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0285601, No Iterations 1
time step continuity errors : sum local = 2736.75, global = -639.791, cumulative = -639.791
ExecutionTime = 4.78 s ClockTime = 5 s
Time = 2
smoothSolver: Solving for Ux, Initial residual = 0.0690268, Final residual = 0.000134747, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.0667625, Final residual = 0.000110036, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.100766, Final residual = 0.000232851, No Iterations 1
GAMG: Solving for p, Initial residual = 0.893178, Final residual = 0.0296773, No Iterations 2
time step continuity errors : sum local = 664.798, global = 147.554, cumulative = -492.237
ExecutionTime = 7.27 s ClockTime = 8 s
Time = 3
smoothSolver: Solving for Ux, Initial residual = 0.539464, Final residual = 0.000930136, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.559662, Final residual = 0.00101096, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.460855, Final residual = 0.000848781, No Iterations 1
GAMG: Solving for p, Initial residual = 0.562958, Final residual = 0.0145996, No Iterations 2
time step continuity errors : sum local = 816.835, global = -396.305, cumulative = -888.542
ExecutionTime = 9.68 s ClockTime = 10 s
Time = 4
smoothSolver: Solving for Ux, Initial residual = 0.181828, Final residual = 0.000369129, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.191699, Final residual = 0.000363309, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.163456, Final residual = 0.000388016, No Iterations 1
GAMG: Solving for p, Initial residual = 0.445896, Final residual = 0.0413308, No Iterations 1
time step continuity errors : sum local = 1300.99, global = -453.554, cumulative = -1342.1
ExecutionTime = 11.96 s ClockTime = 12 s
Time = 5
smoothSolver: Solving for Ux, Initial residual = 0.157346, Final residual = 0.000294152, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.178279, Final residual = 0.000372299, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.12979, Final residual = 0.000339263, No Iterations 1
GAMG: Solving for p, Initial residual = 0.333383, Final residual = 0.0327735, No Iterations 2
time step continuity errors : sum local = 865.563, global = -95.1892, cumulative = -1437.29
ExecutionTime = 14.3 s ClockTime = 15 s
Time = 6
smoothSolver: Solving for Ux, Initial residual = 0.118667, Final residual = 0.000266071, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.14578, Final residual = 0.000287402, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.164746, Final residual = 0.000527067, No Iterations 1
GAMG: Solving for p, Initial residual = 0.340376, Final residual = 0.0297977, No Iterations 1
time step continuity errors : sum local = 933.368, global = 248.937, cumulative = -1188.35
ExecutionTime = 16.52 s ClockTime = 17 s
Time = 7
smoothSolver: Solving for Ux, Initial residual = 0.0951829, Final residual = 0.000200016, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.138162, Final residual = 0.000303547, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.138874, Final residual = 0.00046242, No Iterations 1
GAMG: Solving for p, Initial residual = 0.194145, Final residual = 0.014261, No Iterations 2
time step continuity errors : sum local = 493.546, global = 191.549, cumulative = -996.799
ExecutionTime = 18.97 s ClockTime = 19 s
Time = 8
smoothSolver: Solving for Ux, Initial residual = 0.108677, Final residual = 0.000179489, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.225636, Final residual = 0.000503802, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.11593, Final residual = 0.000352237, No Iterations 1
GAMG: Solving for p, Initial residual = 0.256212, Final residual = 0.0223614, No Iterations 1
time step continuity errors : sum local = 794.502, global = 202.588, cumulative = -794.211
ExecutionTime = 21.27 s ClockTime = 22 s
Time = 9
smoothSolver: Solving for Ux, Initial residual = 0.0982557, Final residual = 0.000304908, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.185531, Final residual = 0.000533666, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.0994782, Final residual = 0.00034999, No Iterations 1
GAMG: Solving for p, Initial residual = 0.293328, Final residual = 0.0275425, No Iterations 1
time step continuity errors : sum local = 1043.34, global = 151.985, cumulative = -642.226
ExecutionTime = 23.59 s ClockTime = 24 s
Time = 10
smoothSolver: Solving for Ux, Initial residual = 0.0937519, Final residual = 0.000187036, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.0959, Final residual = 0.000166799, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.0952078, Final residual = 0.000233081, No Iterations 1
GAMG: Solving for p, Initial residual = 0.368527, Final residual = 0.0356445, No Iterations 1
time step continuity errors : sum local = 1467.9, global = 92.6168, cumulative = -549.61
ExecutionTime = 27.46 s ClockTime = 28 s
Time = 11
smoothSolver: Solving for Ux, Initial residual = 0.164868, Final residual = 0.000163476, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.222946, Final residual = 0.000334008, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.12722, Final residual = 0.000234201, No Iterations 1
GAMG: Solving for p, Initial residual = 0.477769, Final residual = 0.0298537, No Iterations 1
time step continuity errors : sum local = 1505.12, global = 19.7979, cumulative = -529.812
ExecutionTime = 29.72 s ClockTime = 30 s
Time = 12
smoothSolver: Solving for Ux, Initial residual = 0.130392, Final residual = 0.000355599, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.321622, Final residual = 0.000903749, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.12949, Final residual = 0.00030575, No Iterations 1
GAMG: Solving for p, Initial residual = 0.703616, Final residual = 0.0332269, No Iterations 1
time step continuity errors : sum local = 2847.31, global = 90.554, cumulative = -439.258
ExecutionTime = 31.96 s ClockTime = 32 s
Time = 13
smoothSolver: Solving for Ux, Initial residual = 0.0826217, Final residual = 0.000238347, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.130508, Final residual = 0.000542229, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.18985, Final residual = 0.000381059, No Iterations 1
GAMG: Solving for p, Initial residual = 0.833578, Final residual = 0.0424293, No Iterations 1
time step continuity errors : sum local = 6137.85, global = 204.729, cumulative = -234.529
ExecutionTime = 34.2 s ClockTime = 35 s
Time = 14
smoothSolver: Solving for Ux, Initial residual = 0.130854, Final residual = 0.000467332, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.104228, Final residual = 0.000302874, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.119158, Final residual = 0.000711339, No Iterations 1
GAMG: Solving for p, Initial residual = 0.883089, Final residual = 0.0555208, No Iterations 1
time step continuity errors : sum local = 14200.1, global = 11.3717, cumulative = -223.157
ExecutionTime = 36.42 s ClockTime = 37 s
Time = 15
smoothSolver: Solving for Ux, Initial residual = 0.103926, Final residual = 0.000248405, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.233039, Final residual = 0.000832855, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.115342, Final residual = 0.000299915, No Iterations 1
GAMG: Solving for p, Initial residual = 0.893818, Final residual = 0.0572619, No Iterations 1
time step continuity errors : sum local = 18571, global = 876.462, cumulative = 653.305
ExecutionTime = 38.64 s ClockTime = 39 s
Time = 16
smoothSolver: Solving for Ux, Initial residual = 0.186822, Final residual = 0.0013917, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.206877, Final residual = 0.000716568, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.129085, Final residual = 2.18237e-05, No Iterations 2
GAMG: Solving for p, Initial residual = 0.929582, Final residual = 0.0374351, No Iterations 2
time step continuity errors : sum local = 37929.5, global = -19801.9, cumulative = -19148.6
ExecutionTime = 41.11 s ClockTime = 42 s
Time = 17
smoothSolver: Solving for Ux, Initial residual = 0.0989814, Final residual = 0.000175765, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.136444, Final residual = 0.00032175, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.0903033, Final residual = 0.000223593, No Iterations 1
GAMG: Solving for p, Initial residual = 0.893951, Final residual = 0.0713946, No Iterations 1
time step continuity errors : sum local = 89091.8, global = -5091.64, cumulative = -24240.2
ExecutionTime = 43.34 s ClockTime = 44 s
Time = 18
smoothSolver: Solving for Ux, Initial residual = 0.16088, Final residual = 0.000557163, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.232857, Final residual = 0.000855333, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.0866188, Final residual = 0.000243466, No Iterations 1
GAMG: Solving for p, Initial residual = 0.802139, Final residual = 0.0397683, No Iterations 1
time step continuity errors : sum local = 150507, global = -9986.03, cumulative = -34226.2
ExecutionTime = 45.56 s ClockTime = 46 s
Time = 19
smoothSolver: Solving for Ux, Initial residual = 0.0714521, Final residual = 0.000127453, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.0880485, Final residual = 0.000378587, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.0896318, Final residual = 0.00025341, No Iterations 1
GAMG: Solving for p, Initial residual = 0.936714, Final residual = 0.069373, No Iterations 1
time step continuity errors : sum local = 580022, global = -21106.1, cumulative = -55332.3
ExecutionTime = 47.79 s ClockTime = 48 s
Time = 20
smoothSolver: Solving for Ux, Initial residual = 0.104275, Final residual = 5.37614e-06, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.108497, Final residual = 8.93021e-05, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.0775309, Final residual = 0.000112957, No Iterations 2
GAMG: Solving for p, Initial residual = 0.991097, Final residual = 0.0726207, No Iterations 1
time step continuity errors : sum local = 1.70661e+08, global = 369551, cumulative = 314219
ExecutionTime = 51.79 s ClockTime = 52 s
Time = 21
smoothSolver: Solving for Ux, Initial residual = 0.130851, Final residual = 1.23498e-05, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.133453, Final residual = 1.14443e-05, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.123063, Final residual = 8.81908e-06, No Iterations 2
GAMG: Solving for p, Initial residual = 0.980152, Final residual = 0.0740928, No Iterations 5
time step continuity errors : sum local = 5.06379e+09, global = -1.63071e+08, cumulative = -1.62757e+08
ExecutionTime = 54.92 s ClockTime = 55 s
Time = 22
smoothSolver: Solving for Ux, Initial residual = 0.304109, Final residual = 0.000529039, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.0874946, Final residual = 0.000185472, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.114907, Final residual = 6.19314e-05, No Iterations 1
GAMG: Solving for p, Initial residual = 0.948518, Final residual = 0.0931426, No Iterations 1
time step continuity errors : sum local = 1.11399e+10, global = -1.46106e+08, cumulative = -3.08863e+08
ExecutionTime = 57.19 s ClockTime = 58 s
Time = 23
smoothSolver: Solving for Ux, Initial residual = 0.118614, Final residual = 0.0010459, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.129134, Final residual = 6.72522e-05, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 0.101372, Final residual = 2.39837e-05, No Iterations 3
GAMG: Solving for p, Initial residual = 0.423058, Final residual = 0.0259104, No Iterations 1
time step continuity errors : sum local = 2.47431e+14, global = -5.41145e+12, cumulative = -5.41176e+12
ExecutionTime = 59.73 s ClockTime = 60 s
Time = 24
smoothSolver: Solving for Ux, Initial residual = 0.120392, Final residual = 0.000117413, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 0.131364, Final residual = 1.21663e-05, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 0.127022, Final residual = 1.99985e-05, No Iterations 3
GAMG: Solving for p, Initial residual = 0.924117, Final residual = 0.0600726, No Iterations 1
time step continuity errors : sum local = 5.14431e+19, global = 2.03359e+17, cumulative = 2.03353e+17
ExecutionTime = 62.41 s ClockTime = 63 s
I stopped at this stage Because I know this will diverge.
Would you like to look at my BC. May be something wrong in that may be ?
Physics is Inlet at 1.8 bar and outlet at 1.5 bar. Flow in a micro channel with Hydrogen as fluid.
My p file
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 1112347.05;
boundaryField
WALL
type zeroGradient;
INLET
type fixedValue;
value uniform 2002224.694;
OUTLET
type fixedValue;
value uniform 1668520.57;
My U file
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
INLET
type pressureInletVelocity;
value uniform (0 0 0);
WALL
type noSlip;
OUTLET
type inletOutlet;
inletValue uniform (0.0001 0 0);
value uniform (0.0001 0 0);
Regards,
Manoj
incompressible, pressure, reference density, simplefoam, solver
Problem with steadyState solvers using pressure BC Victor OpenFOAM 1 December 14, 2009 06:40
Setting pressure and velocity in inlet Asghari FLUENT 5 September 22, 2006 14:23
Slow convergence in steadystate incompressible simpleFoam suggestions brooksmoses OpenFOAM Running, Solving & CFD 0 March 3, 2006 05:57
pressure inlet in incompressible flow dirk FLUENT 2 June 22, 2005 14:27
incompressible flow - prescribing pressure drop - how best to do it? M. Gerritsen Main CFD Forum 4 January 10, 1999 10:53
