Problem: tetrahedral mesh and interFoam = bad results ?
Like Tree4Likes
  • 2 Post By querdynamik
  • 2 Post By angelmonsalve
Old   June 4, 2010, 10:43
Default Problem: tetrahedral mesh and interFoam = bad results ?
C.Z.
querdynamik is on a distinguished road
i'm using the interFoam-solver (OF 1.6) to simulate a drop/wall-collision.
Because it is much more comfortable and time efficient (compared to blockMesh), i create the geometry and mesh with Salome. In Salome i use the "Netgen(1D,2D,3D)"-mesher to create a tetrahedral mesh.
From previous (and through experiments already validated) works, i pretty much know how the fluid-flow of the drop-impact - at least in the early phase of the simulation - should look like. In this case : The spreading wave-front has to be quiet smooth and spread nearly symmetrically in radial direction from the first point of contact between drop and wall.
When using a hexahedral mesh, the results of the simulation match the experiments pretty good.
Using a tetrahedral mesh (with approx. the same amount of cells and geometry as before) however, i get completely different and inappropriate results. The wave-front "splashes" immediatly and brakes into many little fragments.
For a better clearness, i add these two pictures from topview (both show a quarter of a droplet shortly after it touches the wall and starting to spread) :
With hexahedral mesh:
With tetrahedral mesh:
My questions are : Has someone an explanation for this discrepancy ? Is the interFoam-solver predestined for the use of hexahedral meshes ?
What could be the reasons for this numerical error?
Thanks in advance !
Best regards
C.Z.
lourencosm and joshmccraney like this.
querdynamik is offline   Reply With Quote
Old   October 10, 2015, 15:17
Angel Monsalve
angelmonsalve is on a distinguished road
Hi C.Z.
It's been a long long time since you posted this but I had a similar problem. Some time ago I was running a case using Salome in particular Netgen(1D,2D,3D) with a tetrahedral mesh.
I know that all boundary conditions and solver specifications are correct since I have other simulations done with blockMesh and analytical solutions to compare to.
Did you find any solution to this problem?
angelmonsalve is offline   Reply With Quote
interFoam 1.6.x vs 1.5 : same mesh, same bc but different results nuovodna OpenFOAM Running, Solving & CFD 9 June 14, 2010 06:45
setFields doesn't function for a tetrahedral mesh - interFoam tommie OpenFOAM Pre-Processing 5 April 15, 2010 04:32
[OpenFOAM] 'integrate variables' filter on a polyhedral mesh gives wrong results... jbf ParaView 0 September 4, 2009 05:08
Question on InterFoam moving mesh capabilities ziv OpenFOAM Running, Solving & CFD 0 April 23, 2008 10:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
