InterDyMFoam for breaking wave simulation
Like Tree1Likes
  • 1 Post By egp
Old   April 22, 2010, 10:25
Default InterDyMFoam for breaking wave simulation
yannH
yannH is on a distinguished road
Hello !
I'm actually trying to run a simulation for a breaking wave in 'deep water'. I've already got some good plunging breakers with interFoam . But when I try to run interDyMFoam, for a ras model, I've got this message that never appears with interFoam :
This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
From function emptyFvPatchField<Type>::updateCoeffs()
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 148.
FOAM exiting
I've seen that it could be a multiple declaration for vertices of the mesh but it's not my case, see my blockMeshDict :
convertToMeters 1e-1;
vertices
(0 0 0)
(1 0 0)
(1 0.4 0)
(0 0.4 0)
(0 0 0.01)
(1 0 0.01)
(1 0.4 0.01)
(0 0.4 0.01)
blocks
hex (0 1 2 3 4 5 6 7) (250 100 1) simpleGrading (1 1 1)
edges
patches
cyclic leftAndRight
(0 4 7 3)
(2 6 5 1)
wall lowerWall
(1 5 4 0)
patch atmosphere
(3 7 6 2)
empty frontAndBack
(0 3 2 1)
(4 5 6 7)
mergePatchPairs
Does anyone see what is wrong ?
Yann
yannH is offline   Reply With Quote
Old   April 23, 2010, 06:11
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
You need to provide more information. Your blockMeshDict looks OK (did you run checkMesh to check it?).
What is in your dynamicMeshDict? Which dynamicFvMesh are you trying to use?
Since you have cyclic on leftAndRight, and empty on frontAndBack, what is driving your flow (I presume the motion of your lowerWall is driving the flow?).
egp is offline   Reply With Quote
Old   April 23, 2010, 07:05
yannH
Hi Eric,
Thanks for your reply, I want to use interDyMFoam because i'm interested in dynamic meshing... As I said, i work on breaking wave in deep water and for spilling breakers I need very tiny mesh for the crest.
my dynamicMeshDict looks like :
dynamicFvMesh dynamicRefineFvMesh;
dynamicRefineFvMeshCoeffs
refineInterval 1;
field alpha1;
lowerRefineLevel 0.001;
upperRefineLevel 0.999;
unrefineLevel 10;
nBufferLayers 1;
maxRefinement 2;
maxCells 200000;
correctFluxes
phi
U
dumpLevel true;
(I've just copied one from damBreak example, so i'm not sure...)
Otherwise about your question my lowerWall doesn't move. I initialize the velocity field with funkySetFields, in order to get an unsteady inital sinusoidale wave, that immediately breaks.
Old   April 23, 2010, 07:15
egp
egp's Avatar
Eric Paterson
Hmm, dynamicRefineFvMesh for 2D... that's what I figured. Isn't going to work since it only does isotropic refinement (including in the z-direction of your mesh).
If you really need to do the 2D refinement, you'll have to hack the dynamicRefineFvMesh class and create a 2D version. Otherwise, you will have to make your domain truly 3D and periodic in the z-direction, and let the mesh refinement do its work as designed.
mm.abdollahzadeh likes this.
Old   April 23, 2010, 08:59
yannH
ok, I'll try in 3D with cyclic boundaries for front and back... 3D was my first idea when I began, with an epsilon value into velocity field varying with the width to avoid artificial 3D, but computation time scared me. So it's gonna be the occasion to try it...I'll post screenshots if it works !
thanks Eric,
Yann
Old   June 18, 2010, 10:19
Emanuele
nuovodna is on a distinguished road
any news on 2D dynamicMeshDict ??? I have a problem settings cyclic instead of empty patches: setFields for alpha1 doesn't work and it returns error.
nuovodna is offline   Reply With Quote
Old   July 13, 2010, 11:06
yannH
Is it really useful (or interesting in mechanical terms) to use interDyMFoam instead of interFoam ? I'm asking that because I'm a little lost. My domain doesn't move, only the interface.. What is the interest of dynamic meshing or the situation it is needed ?
Old   July 26, 2010, 09:50
yannH
Hi everyone,
I am testing my example of breaking waves with interFoam or interDyMFoam and with different schemes (for divergence terms of the equation). I have not enough knowledge about efficiency or accuracy about it, so I test with those from dambreak tutorial
div(rho*phi,U) Gauss upwind; // or Gauss limitedLinearV 1;
div(phi,alpha) Gauss vanLeer;
div(phirb,alpha) Gauss interfaceCompression;
or sloshing case.
div(rho*phi,U) Gauss vanLeerV;
div(phirb,alpha) Gauss vanLeer;
Results are different (especially with upwind).. can someone give me advice or tell me what is the best ? thanks
Regards,
Yann
detonation wave simulation Krish FLUENT 15 February 7, 2017 13:38
I lose some fluid during simulation using InterDyMFoam anmartin OpenFOAM Running, Solving & CFD 0 April 20, 2010 16:19
About probe result of Wave simulation shiw FLOW-3D 3 March 13, 2009 10:15
Two question about Wave simulation shiw FLOW-3D 4 February 20, 2009 12:12
Wave simulation Navin Fogla FLUENT 0 March 6, 2008 10:50
