Floating point exception
Like Tree1Likes
  • 1 Post By trex930
Old   April 16, 2010, 16:34
Default Floating point exception
Robin Gilbert
robingilbert is on a distinguished road
Hello guys,
I am trying to run a simulation of a heatsource placed inside an airconditioned room. i used the rhoPimpleFoam solver. my mesh quality is good ( hexahedral meshes) and checkMesh showed no problems at all. but on running the simulation i am getting the following error:
rho max/min : 3 0.3
bounding p, min: -1e+06 max: 3e+06 average: 1e+05
DILUPBiCG:  Solving for epsilon, Initial residual = 0.9, Final residual = 9e-06, No Iterations 645
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 1e-06, No Iterations 6
DILUPBiCG:  Solving for Ux, Initial residual = 0.9, Final residual = 0.04, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 0.02, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.9, Final residual = 0.02, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 0.1, Final residual = 0.003, No Iterations 2
#0  Foam::error::printStack(Foam::Ostream&) in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  ?? in "/lib/libc.so.6"
#3  Foam::hPsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4  Foam::hPsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::correct() in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#5  main in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/applications/bin/linux64GccDPOpt/rhoPimpleFoam"
#6  __libc_start_main in "/lib/libc.so.6"
#7  _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116
please help me solve this problem
robingilbert is offline   Reply With Quote
Old   April 19, 2010, 03:56
matej forman
matejfor is on a distinguished road
It§s pretty easy. The SutherlandTransport routine in function calculate and correct is dividing by zero, which is not allowed in this solar system. To avoid legal consequences, the program crashed. I guess you are running with pressure or temperature to nonphysical values either caused by wrong BCs or initials. I would set all the thermo properties constant to see what is going on and turn the sutherland back later.
more info about the crash info is here.
good luck
matej
matejfor is offline   Reply With Quote
Old   April 21, 2010, 21:55
Robin Gilbert
thank you,
I figured out the problem.... i had given a non-physical value which caused the problem... thanks for helping me out.
Old   June 24, 2010, 04:52
trex930 is on a distinguished road
Hey robingilbert,
How did you manage to fix it? I have been playing around with my boundary conditions, and this thing keeeeeps on popping up. Which condition did you change that made it work? was it in the Pressure file?
T
trex930 is offline   Reply With Quote
floating point error
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
The infamous floating point exception thekay OpenFOAM 7 August 14, 2012 03:01
floating point exception? syd STAR-CCM+ 3 April 20, 2010 19:55
Floating point exception error with small DeltaT rassilon OpenFOAM Running, Solving & CFD 19 September 2, 2009 08:39
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
