Incompatible dimensions....
Like Tree4Likes
  • 1 Post By linch
  • 3 Post By fcollonv
Old   March 19, 2010, 17:20
Default Incompatible dimensions....
Amiga500 is on a distinguished road
Hi all. A CFX and Fluent user having a go at OpenFOAM, and currently making a right hash of it!
OK, simply put, I'm trying to take the existing simpleFoam tutorial pitzDaily and use it on a different mesh (a NACA0012) to get me started. However, I keep getting the following error:
incompatible dimensions for operation
[U[0 1 -2 0 0 0 0] ] == [-grad(p)[0 -3 -2 0 0 0 0] ]
From function checkMethod(const fvMatrix<Type>&, const GeometricField<Type, fvPatchField, volMesh>&)
in file ..\..\src\finiteVolume\lnInclude/..\fvMatrices\fvMatrix\/fvMatrix.C at line 1208.
Obviously, I assumed it was inconsistent dimensions on by "boundary" files within the /0/ folder, however, the dimensions are correct, and are exactly the same as within the OpenFOAM tutorial folder.
After which, I have tried to check whether my mesh is at fault, but checkMesh comes back ok - but I suppose it will not be checking my boundary file within /constant/. I've tried various different mesh, including those available from Polito* for use with AeroFoam - modified for simpleFoam usage, with no success.
*http://www.aero.polimi.it/freecase/?...namic_problems
Anyone any ideas? Even just of where exactly I am being stupid!
Amiga500 is offline   Reply With Quote
Old   March 20, 2010, 07:17
In addition to the above, I can obtain results using potentialFoam... where just U & p are required.
From that, I am guessing that the error lies in how I am relating my boundary conditions to the solver. Either within the /constant/ or /system/ directory, however none of the files within those directories leaps out at me as being the culprit.
Old   March 20, 2010, 08:06
Another post.
Of course, the solver can be got running by screwing around with the dimensions of the input files... (icoFoam used below)
But is it expected to run at p (pressure?) dimensions of
[ 0 2 -2 0 0 0 0]
As as as I am aware, that is m^2/s^2 ?!?!
Whereas I would be expecting:
[ 1 -1 -2 0 0 0 0]
i.e. kg/m/s^2
Old   March 20, 2010, 22:25
Cean
shirazbj is on a distinguished road
For airfoil, why not try the airFoil2d example under the same simpleFoam folder?
I thought p is p/density with that dimension. I have the same question about the cavity example under the potentialFoam.
shirazbj is offline   Reply With Quote
Old   March 21, 2010, 06:24
Gijsbert Wierink
gwierink is on a distinguished road
Yes, indeed, both icoFoam and potentialFoam assume incompressible fluids and use the "density normalized" pressure, making the unit m²/s² instead of the unit of kg/ms² of "real" pressure.
Regards, Gijs
gwierink is offline   Reply With Quote
Old   March 21, 2010, 07:19
Ahh, thanks folks.
Old   January 19, 2011, 05:21
Question one question
Tao Zhu
kongfu is on a distinguished road
Hi gwierink,
I have one question on that. If I run my simulation with rhoSimpleFoam, based on the results of simpleFoam, i.e., I set my startTime to latestTime. Then I have to modify the pressure units. (From density normalized to normal pressure.) Do I also have to change the values of the field?
Thank you very much.
Tao
kongfu is offline   Reply With Quote
Old   January 19, 2011, 05:52
Gijsbert Wierink
Hi Tao,
I suppose yes, since the pressure used in simpleFoam is actually pressure divided by density (see also Section 3.1.2 of the OpenFOAM Wiki) (and this thread with followup).
Regards, Gijs
Old   January 20, 2011, 05:45
Frederic Collonval
Location: Technische Universitaet Munich - Lehrstuhl fuer Thermodynamik
fcollonv is on a distinguished road
Hi Tao,
As said by Gijs, you have to put the real value for the pressure. Indeed in a compressible solver an equation of state is used (usually the perfect gas law) and the density will be deduced from the temperature and the pressure using that law. In case of the perfect law:
rho = p/rT
In the code: http://foam.sourceforge.net/docs/cpp..._8H_source.php line 73
Regards,
Frederic
fcollonv is offline   Reply With Quote
Old   July 7, 2011, 05:20
Illya Shevchuk
linch is on a distinguished road
is there a way to get the dimension of a vol/surfaceScalarField?
linch is offline   Reply With Quote
Old   July 7, 2011, 05:50
Frederic Collonval
Hello Illya,
Yes, you have to call the functions dimensions. For example U.dimensions(). Or you can just write the field by calling the function write (e.g. p.write() ). Then the dimensions are explicitly appearing at the begin of the file (keyword dimensions).
Best regards,
Frederic Collonval
Frederic Collonval
Technische Universität München
Thermodynamics Dpt.
Old   July 7, 2011, 06:06
Illya Shevchuk
Thanks Frederic for the rapid answer!
Another question: I have a surface scalar field:
surfaceScalarField DN2Rhof
                IOobject
                    "DN2Rhof",
                    runTime.timeName(),
                    mesh,
                    IOobject::NO_READ,
                    IOobject::NO_WRITE
                mesh,
                dimensionedScalar("DN2Rho", dimensionSet(1,-1,-1,0,0,0,0), 0.0)
so the dimensions are [1 -1 -1 0 0 0 0]
but when I build the divergence
volScalarField Test = fvc::div(DN2Rhof)
I get the dimensions [1 -4 -1 0 0 0 0].
I thought, the divergence operator has the dimension 1/m, so div(DN2Rhof) should be [1 -2 -1 0 0 0 0], but it doesn't.. Could someone please give me a hint?
mm.abdollahzadeh likes this.
Old   July 11, 2011, 06:27
Frederic Collonval
Hello Illya,
The surfaceField are presumed to be equal to field*Aface (have a look for example to phi in incompressible flow; phi = U*Aface [m^3/s]). So the div operator is simply the sum of surfaceField on each cell-surfaces finally divided by the mesh volume.
Best regards,
Frederic
Frederic Collonval
Thermodynamics Dpt.
Old   June 1, 2012, 08:20
Default SimpleFoam or potentialFoam
  #14
Sören
despaired student is on a distinguished road
I'm thinking about using potentialFoam instead of simpleFoam. In my case I have an incompressible, isothermal and slow (Re<10) flow. I've read somewhere that one can use for very slow and incompressible flows the "potetial theory" to calculate it.
Is this correct and does this mean that I can use potentialFoam to compute the flux in OpenFoam?
best regards
despaired student is offline   Reply With Quote
incompatible dimensions, simplefoam
Incompatible dimensions for operation pramodopen4foam OpenFOAM 10 January 4, 2024 05:51
Different dimensions for FATAL ERROR retech OpenFOAM Running, Solving & CFD 2 August 14, 2007 11:17
Confused by dimensions of Presure jack2000 OpenFOAM Running, Solving & CFD 3 June 5, 2007 11:24
Dimensions of laplacian in PISO loop kumar2 OpenFOAM Running, Solving & CFD 2 July 3, 2006 15:34
Fluent: changing dimensions of a geometry genetaed Madhukar Rapaka FLUENT 3 October 12, 2005 12:40
