January 26, 2010, 14:37 |
Wall treatment : Wall function vs Fine mesh
Rep Power: 17 |
Hello everybody
I'm currently trying to get a simple case working before attacking something more complicated. I'm using the simpleFoam solver since my flow is turbulent and incompressible. The problem consists in evaluating the pressure drop between the inlet and the outlet of a canal. I set up the boundary conditions like this : - for p : I fix the inlet and outlet to p_inlet = X and p_outlet = 0 and see if the mass flow matches the one I have to have in my actual canal. - for u : just fix it to zero @walls Now, for the turbulent parameters k,nuT, epsilon, ... I test two cases : One with wallfunction and one with zerogradient @walls and no wallfunction. Normally, my mesh is fine enough to capture the details of the flow, I checked with the utilities "yPlusRAS" from openFoam, see the results in the pictures. But I have quite huge differences between the simulation with the wallfunctions and without the wallfuctions and I don't understand why so much differences arise between the two ... Do you have an idea where I could be wrong? The results for P, U and yPlus : - For the fine mesh, without wallfunction P : http://yfrog.com/j9champpp U : http://yfrog.com/j9champup - for the same mesh, with wallfunction P : http://yfrog.com/j9champpfp U : http://yfrog.com/07champup yPlus : http://yfrog.com/0ryplusp |
January 26, 2010, 16:50 |
#2 | |
BastiL
Rep Power: 20 |
Additionally, you can not compare results from a low-Re mesh run without wall functions (which you seem to have) with the same mesh run wioth wall functions. It is wrong to run a low-Re-Mesh with wall functions! Another topic is which wall function to use in 1.6 for low-Re models. It should be calculated for nuT afaik. Hope this makes it clear. Regards BastiL |
January 26, 2010, 16:59 |
Rep Power: 17 |
Firstly, a big thanks for your very clear and helpfull answer! I will now look for the LaunderSharmaKE turbulence model but I can't find a tutorial case wich uses this model.
There is just one thing I don't understand : Comparing a low-Re mesh without wall function with High-Re mesh with wall function should be ok... no ? Results should be slightrly different but not totally, am I wrong? Purpose of wall function is to save computational time and to approximate the reality wich is represented here by the low-Re situation, no? Thanks again for the help! |
January 26, 2010, 17:04 |
#4 | |
BastiL
Rep Power: 20 |
In general, yes. However, low-Re remains a model and is also not "reality" but has fewer modeling assumptions. |
January 26, 2010, 17:09 |
Rep Power: 17 |
ok! I got it!
Thanks for the fast answer! It helps a lot |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
Wall function treatment | VEEBS | CFX | 1 | October 10, 2001 00:19 |
