Fully developed flow boundary condition
Like Tree18Likes
  • 2 Post By jits_aps90
  • 4 Post By AlanR
  • 10 Post By ngj
  • 1 Post By ngj
  • 1 Post By nihossain
Old   December 28, 2009, 10:24
Question Fully developed flow boundary condition
Jitender Singh Yadav
jits_aps90 is on a distinguished road
I am working on Jets in Crossflow (JICF) problem as a part of my Masters thesis.
At a face, which is inlet for the jet, I want to implement "A FULLY DEVELOPED FLOW" condition, that will help saving my length of the jet pipe, otherwise I will have to work on :
L(entrance) = 0.06 * Re * D. (for laminar flow)
To avoid this, I want to implement such a condition.
How I can implement such a condition in OpenFOAM.
Thanks a lot.
Luttappy and CFD_beginner12 like this.
jits_aps90 is offline   Reply With Quote
Old   December 31, 2009, 01:51
Alan Russell
AlanR is on a distinguished road
jits,
One method is to set up the inlet profile with your fully developed flow. The /incompressible/simpleFoam/pitzDailyExptInlet tutorial shows how to do this. There is a file called /constant/boundaryData/inlet/points that has a list of points where you will set your profile. The file /constant/boundaryData/inlet/0/U is where you store the velocity (and other) values for each point. I put the formula in a spreadsheet, calculate the velocity profile data and copy it to the Foam file - this method is working well for me. Good luck,
Alan
AlanR is offline   Reply With Quote
Old   January 4, 2010, 00:57
thanks AlanR,
i shall surely try this , seems this should work, even if its 3d I flow, I hope the same things should hold.
thanks once again.
Old   January 4, 2010, 05:43
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Jitender
Another approach is to look in the example
~/OpenFOAM/OpenFOAM-1.6.x/tutorials/incompressible/pisoFoam/les/pitzDailyDirectMapped
where a mapping procedure is carried out between to planes with a given offset between them. The profile from the interior plane is mapped back on to the inlet, hence between these two planes you basically have an infinitely long pipe, and since you are considering laminar flows, then the distance between the two planes is of minor importance as far as the validity of the velocity (and turbulence) profile(s) goes.
I have some nice pictures of a laminar jet in a laminar cross flow on which I performed a POD-analysis, so if you are interested in seeing the results just drop me an email.
Happy New Year,
Niels
ngj is offline   Reply With Quote
Old   January 4, 2010, 06:10
thanks a lot and i wish the same for you.
i viewed the pitzDailyMapped case, but i couldn't find out at what offset the values are mapped.
and how many times the values are mapped. Are they mapped untill the flow becomes fully developed.
thanks
Old   January 4, 2010, 06:52
ngj
Hi
Look at the following file in the tutorial case: "system/changeDictionaryDict". Running the utility changeDictionary before running the application changes the boundary type in constant/polyMesh/boundary with whatever is stated in the first file. In the first file you also state the offset vector of the given patch.
I will send you an email later today with my results.
Bests,
Niels
Asgarian likes this.
Old   September 8, 2011, 12:29
Wink Hi
Ali Asgarian
Asgarian is on a distinguished road
I guess this page was active long before, but it is still worthy to ask my question.
I need to simulate fully developed flow in a geometry (e.g. pipe) with one inlet and one outlet. I prefer to avoid modelling a long pipe; can I implement the same method to model small piece of pipe instead?
Tanx
Asgarian is offline   Reply With Quote
Old   November 2, 2011, 17:10
Naser Imran Hossain
nihossain is on a distinguished road
Thanks a lot.
Hey, do you have any idea how to do that in FLUENT? I'm having the same problem where I need a fully developed flow at the inlet but don't want to change the pipe length. Some help would be really appreciated.
BHUVANESH likes this.
nihossain is offline   Reply With Quote
Old   November 17, 2017, 09:34
Default fully developed inlet profile for 3D pipe flow
Shafik Walakaka
walakaka is on a distinguished road
thanks AlanR,
thanks once again.
How did you manage to translate that code into 3D? I am trying to simulate a simple pipeflow with a fully developed profile at the inlet
walakaka is offline   Reply With Quote
Old   May 31, 2023, 07:17
Murtadh
CFD_beginner12 is on a distinguished road
Hi all ,
how can I do the same in Ansys?
(maintain a fully developed profile at inlet)
CFD_beginner12 is offline   Reply With Quote
boundary condition, fully developed flow.
back flow at pressure out flow boundary condition durga Main CFD Forum 0 December 8, 2009 01:42
Writing an expression for fully developed flow! Usman CFX 12 December 20, 2007 12:26
fully developed flow JAS FLUENT 4 February 12, 2007 07:01
Fully Developed Boundary Condition at Duct Inlet Twiti CFX 1 January 24, 2005 02:31
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
