dynamicRefineFvMesh on polyhedral meshes
Like Tree3Likes
  • 3 Post By potentialFoam
Old   October 21, 2009, 06:57
Default dynamicRefineFvMesh on polyhedral meshes
Frank Bos
lr103476 is on a distinguished road
Hi everyone!
It's been a while since my last forum post, I was extremely busy wrapping up my PhD thesis. If time allows me, I will increase my message board involvement! Now the problem.
I am interested in using automatic refinement on arbitrary polyhedral meshes, which can be generated using ansys, snappy and some other tools. However, when running interDymFoam on the damBreak utility the following error occurs:
Selected 1178 cells for refinement out of 7854.
hexRef8 : Dumping cell as obj to "/media/data/OpenFOAM/frank-1.6/run/tutorials/multiphase/interDyMFoam/ras/damBreakWithObstacle/cell_9.obj"
cell 9 of level 0 does not seem to have 8 points of equal or lower level
cellPoints:6(28 29 30 31 32 33)
pointLevels:6{0}
Has anyone used dynamicRefineFvMesh before? Did anyone encounter and solve this problem?
Best regards,
Frank Bos
Frank Bos
lr103476 is offline   Reply With Quote
Old   October 21, 2009, 14:29
Sandeep Menon
deepsterblue will become famous soon enough
I believe dynamic refinement is currently supported only for 3D meshes with hexahedral cells. That would explain the error - it expects cells containing exactly 8-points for octree sub-division.
Polyhedral mesh refinement is not a trivial problem. I think it might help to decompose polyhedral cells into tetrahedra, refine/de-refine/optimize, and then agglomerate appropriately. But to do this automatically and intelligently would be quite an accomplishment indeed.
Hope this helps.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   May 30, 2011, 03:09
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Also face this problem: I intended to refine initially coarse grid according to my solution, but it fails on tet, prisms and pyramids, all that don't have 8 vertices should not pass)))
Is dynamicRefineFvMesh improved in OF1.7?
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   August 1, 2016, 12:24
Peter
potentialFoam is on a distinguished road
Dear Foamers,
I also face the same problem using adaptive/ dynamic mesh refinement in Foam (here OF version 3.0.1). The next figures show the refinement of a hexahedral mesh (generated with Hexpress5.1) behind a foil.
This is the original mesh:
And this is the refined mesh (refined cells chosen according to a vortex identification criterion; some dark grey cells fulfill this criterion too):
The dark grey colored cells mark 'protedtedCells' which are detected by 'dynamicFvMesh'. These cells contain hanging nodes and hence can be describes as 'polyhedral' cells. Besides, Foam seems not to be able to refine these cells. But: I really want to use some kind of adaptvie/ dynamic mesh refinement with this kind of grid.
Can someone help me out?
Regards,
Peter
potentialFoam is offline   Reply With Quote
Old   December 14, 2016, 11:59
Peter
I found the solution here in conjunction with snappyHexMesh
http://www.openfoam.com/version-v1606+/meshing.php
under "snappyHexMesh refinement and unrefinement".
Thanks a lot to OpenCFD Ltd. for their valuable extensions!
Best Regards,
Peter
makaveli_lcf, Fschi and SGWANG like this.
Old   May 11, 2020, 13:03
Quentin
lacostq is on a distinguished road
Hello Everyone,
I have experienced similar problem with AMR on snappyhexmesh case :
The problem was that cells with refinement level 2 were immediately next to level 0 cell.
Doing some distance mode region refinement solved the problem :
The surface refinement is of level 3, buffer layers are of level 2.
Region refinement :
stlsurface
mode distance;
levels ((0.5 1));
lacostq is offline   Reply With Quote
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 08:06
Polyhedral in parallel drdr18 FLUENT 5 April 3, 2009 18:56
[Commercial meshers] Importing Fluent polyhedral meshes fra76 OpenFOAM Meshing & Mesh Conversion 2 October 11, 2008 05:44
how to make polyhedral cell meshes mmacrb FLUENT 3 February 2, 2007 15:19
Polyhedral meshes in STAR-design Lee Siemens 3 March 10, 2005 17:43
