September 5, 2009, 10:40 |
pyFoamPlotWatcher is not working
Arvind
Rep Power: 17 |
I want to watch residuals.....so i have installed PyFoam- 0.5.2.... but...... while executing pyFoamPlotWatcher ......it says
File "/usr/local/bin/pyFoamPlotWatcher.py", line 3, in <module> from PyFoam.Applications.PlotWatcher import PlotWatcher File "/usr/local/lib/python2.6/dist-packages/PyFoam/Applications/PlotWatcher.py", line 6, in <module> from PyFoam.Execution.GnuplotRunner import GnuplotWatcher File "/usr/local/lib/python2.6/dist-packages/PyFoam/Execution/GnuplotRunner.py", line 86 with="steps", ^ SyntaxError: invalid syntax I am using UBUNTU-9.0.4 AND OF-1.6. I know for this forum this is not a major problem......please spare some time to give ur suggestions Thanks in Advance Last edited by arvind_arya; September 6, 2009 at 12:55. |
September 7, 2009, 14:35 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Please do not cross-post |
May 31, 2010, 21:14 |
same error!!
Ramnik Singh
Rep Power: 17 |
Hey i am facing the same problem....did u find a solution to it??
June 1, 2010, 08:46 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
December 13, 2010, 07:09 |
#5 | |
Jan Löhrmann
Rep Power: 16 |
I would like to print the plots of pyFoamPlotWatcher.py and tried the following commands. Quote:
I'm using OF-1.7.1 on Mac OSX 10.6.5 and have the pyFoam(PlotWatcher) version 0.5.4. |
December 13, 2010, 15:43 |
#6 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
It is not a Mac-problem per se (I develop that stuff most of the time on such a thing). Is there any additional output after stopping the watcher? Bernhard |
August 16, 2016, 10:32 |
Charles K.
Rep Power: 10 |
If you want the residualplot in pdf Format to be saved in the work directory, just use :
pyFoamPlotWatcher.py log --hardcopy --format-of-hardcopy=pdf |
ICEM working directory setting | Bogesz | CFX | 2 | October 8, 2008 08:45 |
Working Principle of Micro-Oven | aero | Siemens | 2 | January 31, 2007 06:00 |
Help required on working of Micro-oven | aero | CFX | 4 | January 19, 2007 09:21 |
Help required on working of Woven | aero | FLUENT | 0 | January 16, 2007 07:25 |
Team working on CFD code | Spontex | Main CFD Forum | 5 | August 11, 2006 15:51 |
