interface tension question with interFoam solver
Like Tree2Likes
  • 2 Post By caw
Old   May 29, 2009, 11:03
Default interface tension question with interFoam solver
openTom is on a distinguished road
Hi Foamers,
i'm trying to set up several testcases for the interFoam solver at the moment, in order to analyze it with respect to e.g. gravity currents.
The surface tension in an air water system can be set with the sigma term under transportProperties to a value of 0.07 kg/s².
But for the case of having a closed box with two liquids (in contact) inside i will have to define two values of surface tension or one value of interface tension, i think?! Is it right then to take only the difference of the two surface tension values and store it under the sigma term in the transport properties?
Let's say i'm using a water and saltwater system which is normally miscible (but interfoam treats it as unmiscible), so i should have to set the sigma to zero, right?
Thanks
openTom is offline   Reply With Quote
Old   May 29, 2009, 11:42
caw
Christian Winkler
caw is on a distinguished road
surface tension is a specific property for a given system, eg. air-water (thats the 0.072). Once you have a different system like water-oil you have to use measured values for this system.
Btw: i would think that the interfoam solver is not appropriate for a case with MISCIBLE fluids. you might want to try a different approach.
best regrads
christian
caw is offline   Reply With Quote
Old   May 29, 2009, 12:19
Thank's for your reply.
The important fact in my case is the density difference of the two liquids. In my case this is about 5kg/m³. The liquids should be treated as unmiscible, that's why i'm using interFoam, but here is the problem. Since water and saltwater are miscible, the interface tension should be zero. Please correct me if I'm wrong. Is interFoam solving right, if i use a sigma with the value zero? I could also set a hypothetical value of let's say 0.001 to keep the liquids unmiscible.
The best would probably be to investigate an unmiscible water oil system where the interface tension is known, but the saltwater-water case was solved with an other cfd software and i want to compare the results.
Old   May 29, 2009, 14:00
caw
Christian Winkler
Ok, i understand. Setting sigma to zero is not a problem at all. it simple switches of an additional source term in the momentum balance, that accounts for the surface tension at the phase interface (0< gamma<1).
The force caused by surface tension is modelled my a CSF model. CSF = continuum surface force.
This converts the surface force into a volume force, which can be included into our FVM.
Best regards
christian
Pirlu and fredup like this.
Old   May 29, 2009, 14:18
Thank you.
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
Question abt. the Riemann analytic solver jinwon Main CFD Forum 0 July 16, 2007 15:11
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
