New linear system solvers
Like Tree4Likes
  • 4 Post By joern
Old   April 28, 2009, 01:22
Default New linear system solvers
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Hi All,
Suppose that I want to rewrite a linear system solver in another programming language and implement it in OpenFOAM. If I begin with PBiCG.C, how can I read all of the values from the "A" matrix and "b" vector so they can be moved to a new list in the other programming language? In other words, what type of sparse matrix storage is used in OpenFOAM? Are we talking "Modified Sparse Row" or "Compressed Spares Column" type or something else? How do lduAddressing, matrix_, coupleBouCoeffs_, coupleIntCoeffs_, and interfaces_ relate to each other? I have looked into PBiCG.C and it would be great to have some help. Suggestions?
Dan
chegdan is offline   Reply With Quote
Old   April 28, 2009, 14:31
Assistant Moderator
Bernhard Gschaider
Originally Posted by chegdan View Post
Hi All,
Dan
I never fiddled around with the linear solvers, so I can't give you much help. But there seems to be some information on addressing in the header-file of lduAddressing. Other than that I can only recommend clicking through the Doxygen.
Bernhard
Old   April 28, 2009, 15:55
Joern Bader
joern is on a distinguished road
Uff, i analysed the linear Solvers last year. I try to explain, how the linear systems are organised.
First, the class fvMatrix is not a Matrix, it is a whole linear system. The class lduMatrix is a whole system, too.
I think the interesting part for you are the arrays:
upper(), lower(), diag(), source()
diag and source should be clear. upper and lower contain the U and L parts of the lduMatrix. the elements of these arrays get adressed by upperAddr(), lowerAddr() and ownerStartAddr().
upperAddr contains the rows of Upper and the colums of lower, lowerAddr the colums of upper and the rows of lower.
So the arrays are sortet for A*x multiplication.
If you want to get Transpose[A] you have to use
upper()[losortAddr()], lower()[losortAddr()], upperAddr()[losortAddr()], lowerAddr()[losortAddr()] and losortStartAddr() for adressing.
all the arrays, i mentioned, are acessible over member-functions of the lduMatrix.
hope that helps.
joern is offline   Reply With Quote
Old   May 7, 2009, 14:48
Daniel P. Combest
Thanks for your replies.
Bernhard: I did see the header file and it was a little bit confusing, but I think I'm getting it. Thanks for your pointers.
Joern: I will look more into what you've posted. I recently have been handed another short-term project and have to leave my efforts for a week or two more. Thanks for your help though, its greatly appreciated.
Dan
Old   May 8, 2009, 05:09
Henrik Rusche
henrik is on a distinguished road
Dear Dan,
I am not sure what you are planning to do, but it might interesting for you to know that there is a set of enhanced AMG solvers in OpenFOAM-extend. More information can be found in this paper.
http://powerlab.fsb.hr/ped/kturbo/Op...pmAIAA2007.pdf
Best Regards,
Henrik
henrik is offline   Reply With Quote
Old   May 8, 2009, 13:53
Default I'll take a look, thanks .
Daniel P. Combest
Henrik,
I'll take a look at the paper. I have already downloaded the -dev version and compiled successfully. However, I have not looked at the new AMG solvers. Thanks for pointing that out. I'm actually looking at the possibility of using CUDA as a linear system solver and needed to understand how the matrices are addressed so they can be passed to the GPU. This is not my main project, only a little fun. I have seen several threads pertaining to porting openFoam to run on a GPU...but I think its a bit overkill to port more than the linear system solvers. Thanks again.
Dan
Old   July 22, 2009, 09:14
Heiko Herrmann
sorcerer is on a distinguished road
Hi Dan,
I think you are right with only porting the linear system solvers.
How is the state of your project? Would you share your experience?
Greetings,
Heiko
sorcerer is offline   Reply With Quote
Old   August 25, 2009, 17:25
Default OpenCL may or may not be better
Daniel P. Combest
I had been working on developing in CUDA for a bit, but took some time off since another project that took priority was put in front of me. I haven't finished my solver yet, but now I'm looking into OpenCL as an alternative to CUDA. OpenCL might be better option for those not using nvidia products. I will look into it in the next few months once I have more time.
Dan
Old   March 23, 2010, 09:13
Nick Gardiner
NickG is on a distinguished road
Hi Dan
How's the port going? Any luck?
I may be a bit after the event but...
Looking at the thesis http://ce.et.tudelft.nl/publicationf...063_thesis.pdf it would seem that compressed row or modified sparse row formats are better for parallelisation than the ldu format, although I wonder if some extra temporary local variables could overcome this problem. The compressed row format already has a converter written in openFoam so unless you want a lot of rewriting it may be easiest to use that, although you will lose some of the time that you'd gain in CUDA with the conversion process.
If you want to know how all this hangs together then you'll have to ask someone else as I've only just started down this path...
Cheers
Nick
NickG is offline   Reply With Quote
Old   April 30, 2010, 06:41
John Deas
johndeas is on a distinguished road
would it be possible to have a test case that uses RPM(3) as a solver ?
Thanks !
johndeas is offline   Reply With Quote
Old   April 30, 2010, 09:05
Nick Gardiner
Hi John
What's RPM(3)?
Old   April 30, 2010, 11:22
John Deas
3rd Recursive Projection Method, this is what the article cited by Prof. Hrvoje Jasak is about.
Article to be found at http://powerlab.fsb.hr/ped/kturbo/Op...pmAIAA2007.pdf
Direct vs Iterative Linear Solvers for non-linears bill Main CFD Forum 16 November 5, 2014 08:18
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Linear system solver elias FLUENT 0 November 19, 2008 10:30
flop count for linear system solvers no_name Main CFD Forum 2 December 7, 2005 23:10
More advise on libraries to solve linear system Ricardo Bonon Main CFD Forum 0 May 18, 2000 19:37
