Initial data for perturbU
Like Tree1Likes
  • 1 Post By cedric_duprat
Old   April 24, 2009, 05:56
Default Initial data for perturbU
Leonardo Giampani Morita
leonardo.morita is on a distinguished road
I'm going to work with LES and was told to start studying the cyclic channel case. I ran the tutorial and now I'm interested on testing the perturbU utility. However, I didn't find any information about the entries that are needed, other than the Retau in the transportProperties, so I'd like to know if somebody could explain how I can control the perturbations and how the files U, p etc( in the 0 folder) must be initialized (with arbitrary conditions?).
Thank you,
Leo
leonardo.morita is offline   Reply With Quote
Old   April 24, 2009, 07:45
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi Leo,
The point is that you don't need other information. And, because Retau is used to define the amplitude of the noise, you can choose it arbitrary.
Check on the LES thread for reference paper of this tool (Schoppa and Hussain Fluid Dynamics Research 2001). Eugene de Villier Ph'd is still really good to get information for LES with OpenFOAM.
Then, you can have a look at the implementation, you don't need to be a C++ expert to get it. The main idea is to add a decreasing sinusoidal random noise to a parabolique profile for the velocity.
I hope It will help.
Cedric.
PS: for more information about LES channel flow, you can have a look there http://openfoamwiki.net/index.php/Si...ion_test_cases
and maybe add some usefull information for the community.
songwukong likes this.
cedric_duprat is offline   Reply With Quote
Old   April 24, 2009, 08:28
Thank you Cedric,
But should I have something (U, p etc) in the 0 folder before running perturbU? Or these files will be created by the application?
Leo
Old   April 24, 2009, 08:55
Forget it...I realized that what I need to do is just to have an U file there, with an arbitrary profile (for example, a zero-velocity field)...
channel, perturbu
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 04:32
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
