Accessing fields and dictionaries from within a BC implementation
Like Tree20Likes
  • 3 Post By alberto
  • 4 Post By woody
  • 8 Post By deepsterblue
  • 1 Post By woody
  • 4 Post By andrea
Old   December 5, 2005, 16:09
Default How can a field defined in the
Alberto Passalacqua
How can a field defined in the solver code be accessed from within the code of a boundary condition?
As explained here http://www.cfd-online.com/OpenFOAM_D...tml?1133622442, I'm trying to add Johnson and Jackson's BCs to the twoPhaseEulerFoam solver, but I can't have access to the solver fields. I get the error:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.2 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : twoPhaseEulerFoam . Rhodes2D
Date : Dec 05 2005
Time : 21:06:15
Host : dimension4400
PID : 13204
Root : /home/alberto/OpenFOAM/alberto-1.2/run/FluidBeds
Case : Rhodes2D
Nprocs : 1
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading transportProperties
--> FOAM FATAL ERROR :
request for volScalarField alpha from objectRegistry region0 failed
available objects of type volScalarField are
0
From function objectRegistry::lookupObject<type>(const word&) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/objectRegistryTempl ates.C at line 122.
FOAM aborting
I try to read the alpha field as follows:
const fvPatchField<scalar>& alpha = lookupPatchField<volScalarField,
scalar >
"alpha"
Also, how can I have access to the kineticTheoryProperties dictionary from the BC code? I get an error message which tells me the dictionary can't be found if I try to read from it.
Thanks in advance,
Alberto
atulkjoy, Zhiheng Wang and TeddyL like this.
Alberto Passalacqua
Old   July 16, 2010, 04:29
Tobias Holzinger
woody is on a distinguished road
Hi Alberto,
I had a similar problem: if you want to access the kineticTheoryProperties
from the constant folder you can get it by
IOdictionary kineticTheoryProperties
IOobject
"kineticTheoryProperties",
this->db().time().constant(),
this->db(),
IOobject::MUST_READ,
IOobject::AUTO_WRITE
and then
scalar Whatever =
readScalar
kineticTheoryProperties.lookup("Whatever")
For your second problem, you need to crate a mesh:
Foam::fvMesh mesh
Foam::IOobject
Foam::fvMesh::defaultRegion,
this->db().time().timeName(),
this->db().time(),
Foam::IOobject::MUST_READ
if you want to extract at some characteristic point...
otherwise, the whole mesh vol<Type>Field can be read by eg.
const GeometricField<scalar, fvPatchField, volMesh>& rhofield =
this->db().objectRegistry::
lookupObject<GeometricField<scalar, fvPatchField, volMesh> >
"rho"
or
const GeometricField<vector, fvPatchField, volMesh>& Ufield =
lookupObject<GeometricField<vector, fvPatchField, volMesh> >
"U"
woody is offline   Reply With Quote
Old   July 16, 2010, 10:24
Sandeep Menon
deepsterblue will become famous soon enough
Goodness, no! Do NOT create a mesh every time you want to access something related to it..
You can access the objectRegistry using the fvPatch db() function:
template<class Type>
const Foam::objectRegistry& Foam::fvPatchField<Type>::db() const
    return patch_.boundaryMesh().mesh();
You can then use this to lookup whatever you like (dictionaries, volFields, and their associated boundaries).
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   July 16, 2010, 10:56
Tobias Holzinger
Hey Sandeep,
Thanks for your advice...
I already realized it but did it like:
this->dimensionedInternalField().mesh()
Do you also have a hint of how to acces the Cp value in an easier way as
#include "basicThermo.H"
const basicThermo& thermo=this->db().objectRegistry::lookupObject<basicThermo>("t hermophysicalProperties");
const scalarField Cpw = thermo.Cp();
thx in advance
Tobi
fumiya likes this.
Old   July 16, 2010, 11:05
Default eaxmple
Andrea Petronio
andrea is on a distinguished road
this should be an example:
const dimensionedScalar& readNu = db().lookupObject<IOdictionary>("transportProperties").lookup("nu");
should it be correct
Abdrea
andrea is offline   Reply With Quote
Old   July 19, 2010, 04:55
Thumbs up
Tobias Holzinger
Hi Andrea.
thanks for the quick reply, but there are two things...
1. your code does not work on my BC :
mybc.C: In member function ‘void Foam::mybc<Type>::myfunction()’:
mybc.C:165: error: expected primary-expression before ‘>’ token
mybc.C:165: error: request for member ‘lookup’ in ‘("transportProperties")’, which is of non-class type ‘const char [20]’
I think it is due to the fact, that ‘lookup’ doesnt work here...
2. I don't want to read a dictionary IO but call a member function called Cp()....
thx altough... my version works anyway...
Old   July 26, 2010, 18:47
Default Reading alpha and alphaEff
n/a
deji is on a distinguished road
Hello everyone. I have a similar question to what has being asked. I think mine is easier to answer . Well, I am writing a post-processor to an LES simulation I performed and I am trying to read the thermal diffusivity and effective-thermal diffusivity, alpha and alphaEff. Is what I am doing correct:
IOdictionary LESProperties
IOobject
"LESProperties",
runTime.constant(),
mesh,
IOobject::NO_WRITE
dimensionScalar alphaEff
LESProperties.lookup("alphaEff")
LESProperties.lookup("alpha")
deji is offline   Reply With Quote
Old   July 26, 2010, 18:51
n/a
Hello everyone. I have a similar question. I am trying to write a post-processor and I need the values from the LESProperties and thermophysicalProperties, and I am not sure if the code I have here is correct. I am just working my way around OpenFOAM and trying to get comfortable with the code. Thanks.
// Read LESProperties & thermophysicalProperties
IOobject
"LESProperties",
runTime.constant(),
mesh,
IOobject::NO_WRITE
Old   September 14, 2010, 11:14
Ozgur Kirlangic
ozgur is on a distinguished road
I have got a question about the "use of IOdictionary for this purpose"..
Does this mean that at every time step when the boundary condition is updated (or called), a disk I/O operation is performed for the value of "nu" ?? Does the name "IOdictionary" stand for that??
It is very important for me.
Thank you,
Ozgur
Originally Posted by andrea View Post
Abdrea
ozgur is offline   Reply With Quote
Old   January 4, 2011, 08:08
Angry Access Data from same bc but different parameter
Tobias Holzinger
Hi All!
New Year, new problems, i am trying to figure out how to access a variable from a different parameter for the same patch at each timestep e.g., read the amplitude and frequency values from the velocity oscillatingFixedValue BC at the current time step and use them as input parameters for the pressure boundary condition.
So far I manage to get:
//load the internal velocity field
    "U"
   label patchi=this->patch().index();
Info << "Ufield Boundary" <<  Ufield.boundaryField()[patchi] << endl;
Somehow it should work with sandeeps version, but I don't manage to code it right...
Looking forward for quick reply...
Tobias
Tobias Holzinger
Chair of Thermodynamics, TU München
Old   January 7, 2011, 08:36
Tobias Holzinger
Sorry I can't handle your code ... can you give a more detailed example?
Tobias Holzinger
Old   December 6, 2011, 08:39
Rob
robbirobocop is on a distinguished road
I have a similar problem.
In every loop I write out a constant scalar to "scalarDict" which is inside of the constant directory. The entry for the scalar is: fluxIn 0.21;
Now I want to import this value and assign it to a boundary condition, e.g. flowRateInletvelocity. However, this does not work with any of the above posted hints.
scalarDict is of type "IOdictionary" and is located in "createFields.H".
The scalarDict.set(name, value) is inside the "solver.C" file.
Compiling the solver via "wmake" works well without any error message.
So, what kind of "lines" do I have to put inside my "U" file to successfully import the flowRate I need for my BC?
Any kind of help would be appreciated.
robbirobocop is offline   Reply With Quote
Old   December 6, 2011, 10:30
Rob
Alright, I fixed it myself.
Since the scalarDict is updated on every timestep ( the value is just overwritten ).
How can I manage to reload the value in my BC?
For now the BC flowRate value is 3.8E-05 (the starting value) all the time.
So it is not updated...
RhoSimpleFoam tutorial test case system dictionaries flavio_pergolesi OpenFOAM Running, Solving & CFD 2 April 17, 2014 09:41
Using wildcards regexes in dictionaries chtrapp OpenFOAM Pre-Processing 4 July 18, 2012 12:37
Passing parameters from dictionaries ngj OpenFOAM Running, Solving & CFD 0 June 29, 2008 12:25
Thermo dictionaries grtabor OpenFOAM Running, Solving & CFD 0 July 7, 2005 14:07
Dictionaries written by FoamX Mattijs Janssens (Mattijs) OpenFOAM Pre-Processing 1 January 3, 2005 14:44
