June 16, 2006, 07:02 |
Hello everybody,
Did anybod
Alexander Jarosch
Rep Power: 17 |
Hello everybody,
Did anybody already modify the simpleFoam solver to include a body force term, i.e. gravity. I would like to add that and look for some hints. Thanks for all advice |
June 16, 2006, 08:27 |
look at buoyantFoam, it is in
Markus Hartinger
Rep Power: 17 |
look at buoyantFoam, it is in there
markus |
June 16, 2006, 09:02 |
thanks, right I just look at t
Alexander Jarosch
Rep Power: 17 |
thanks, right I just look at that. I'm new to OpenFoam so it might take me a while to get into the code. buoyantFoam uses a variable density as I understand it, whereas I treat a constant density case.
I want to let the fluid move driven by gravity. Is it maybe simpler to just define the pressure gradient instead of including it in the solver? I guess this is possible in OpenFoam ;-) |
June 16, 2006, 09:58 |
twoLiquidMixingFoam is incompr
Markus Hartinger
Rep Power: 17 |
twoLiquidMixingFoam is incompressible, try that
January 3, 2012, 09:11 |
Rep Power: 16 |
Is this the last word in this case?
Is it not possible to model steady-state, single phase, incompressible, laminar flow with gravity in OpenFoam? |
May 10, 2013, 03:27 |
Dongyue Li
Rep Power: 18 |
May 14, 2013, 01:03 |
#7 | |
Instead of variable density suppose I want constant density. Do you think the answers in both cases will differ? I too want to know the answer.. Last edited by Tushar@cfd; May 14, 2013 at 02:10. |
May 14, 2013, 11:44 |
#8 | |
Sachin Kanetkar
Rep Power: 17 |
I guess you might have already traced out solution.... Anyways if your rho is fixed you just have to add it as source term in UEqn.h() with g as vector. u may define them in create Fields.h. So the efftect will be seen as source term in weight of fluid in only 1 momentum eq but rest would remaiin the same as before... Correct me if i am wrong ... Sachin |
May 15, 2013, 00:32 |
#9 | |
I have already done that thing with buoyantSimpleFoam... But later dropped the idea as it didn't suit my requirements and worked with Boussinesq approximation. If you see the code here variable density is needed for buoyancy.. I think I should say in detail, since I am working with buoyantBoussinesqSimpleFoam... I have solution but these differs from the numerical approach of the papers. For a very simple case the results matches exactly with the journal papers. But for the case of complex geometry results are showing deviations from paper. Which I don't think is permissible, with the use of higher order schemes and since the results are reaching convergence(I have set below 1e-05 for all variable is my convergence criteria). When I happen to see the Isotherms and streamlines the dissipations seems to match with the paper but the gradT value is differs. It seems convective dissipation of heat in OF is more. Anyways, I am trying to figure it out. Is there anyone who has solved a complex case of natural convection (especially with buoyantBoussinesqSimpleFoam)? Last edited by Tushar@cfd; May 15, 2013 at 07:28. |
May 15, 2013, 00:56 |
#10 |
Well,
Anyone successful in solving natural convection of complex geometry (like heat transfer inside a room with a source object). If yes please, try to share your views.. Are you getting the exact results (as compared with numerical results of papers)? Thanks in Advance.. Last edited by Tushar@cfd; May 15, 2013 at 07:28. |
May 15, 2013, 09:13 |
#11 |
Sachin Kanetkar
Rep Power: 17 |
Sounds interesting ... Can you share the data ... what is the complexity...
CAn you share the difference ... Points you can check - 1. What is effect of variation in Tref in boussinesq approximation 2. What is your Rayliegh number ... is it very high .. in which case it would turbulent flow 3. Changes in mesh Best Luck Sachin |
May 15, 2013, 23:32 |
#12 | |
I didn't understand this. What do you mean by variation in Tref in boussinesq approximation? Can you please explain, what kind of variation you are talking about? Condition 2: I already shared the data check my post... http://www.cfd-online.com/Forums/ope...implefoam.html Condition 3: Well, if I am right then mesh size won't have much impact on results in case of SIMPLE algorithm. Last edited by Tushar@cfd; May 16, 2013 at 00:49. |
May 16, 2013, 07:47 |
#13 |
Sachin Kanetkar
Rep Power: 17 |
I was refering to your ref temperature/ambient temperature...
I understand that these solvers might have some problems with complex geometries but the case described doesnt really seems to be a complex geometry ... For mesh, I dont know why it is not important. your concern from what understand is not something about no convergence but about dissipation of heat. So, if the mesh does capture the heated boundary condition, the results might improve. To check if the OF is giving some problem, you can compare it with some other s/w. With no real case results, we can keep guessing what you can try... If I could still thing of any more ideas, I would keep you posted. If you do solve your problem, let me know. Best Luck, Sachin |
May 9, 2019, 10:04 |
#15 |
Ali Shayegh
Rep Power: 11 |
Does anyone know how 2 remove T equation from buoyantBoussinesqSimpleFoam , so that it would be converted to simpleFoam with gravity included..?
June 16, 2022, 14:43 |
#16 |
Mahmoud
Rep Power: 5 |
DPM Body Force | Sandilya Garimella | FLUENT | 1 | April 8, 2008 03:30 |
Flow under gravity force | danvica | OpenFOAM Running, Solving & CFD | 0 | December 12, 2007 10:22 |
Body force | Jacob | FLUENT | 0 | August 4, 2003 16:38 |
how to treat the gravity force | Angela | Main CFD Forum | 0 | January 17, 2003 03:39 |
UDF-Body Force | Fluent_User | FLUENT | 0 | August 9, 2002 09:07 |
