Blow up of reynolds stress turbulence model
Like Tree1Likes
  • 1 Post By svens
Old   July 17, 2006, 05:39
Default Hi, I have a channel with a
newbee
I have a channel with a incompresible flow and high Re number, stedy state. I run my case in a slightly modified version of the simpleFoam application. I want to try the two Reynold stress based turb. models LRR and LaunderGibsonRSTM. I use the following values for R()() in at the internal ande inlet patches of the channel.
inlet & internal
R=[0.564 0 0 0 0.564 0 0 0 0.564];
(Rxx=Ryy=Rzz=0.564)
which is the same as 2*k/3 in my case.
The ploblem is that my time step continuity error blows upp pretty quickly and the calculated value of epsilon follows.
With other turbulence models I experiance many itterations for pressure (500) but the outcome looks nice.
Does anyone have a sugestion on how to avoid the blow upp using Reynold stress based turbulence models?
Thanks
/Erik
Old   July 25, 2009, 12:22
Default Similar problem
Barath Ezhilan
barath.ezhilan is on a distinguished road
Hey Newbee..
I am experiencing a similar problem here. Any idea how to get rid of the problem?? Did you find the solution to the problem??
barath.ezhilan is offline   Reply With Quote
Old   November 24, 2009, 15:09
Sven Schweikert
svens is on a distinguished road
Hi Erik and Barath
Did you try to use a k-epsilon calculation as initial condition for the RSTM run?
I have good experiences with precalc with an EVM, create the Reynolds-Stress-Tensor with post-processing tool 'R' and than switch to the RSTM. Be aware that the 'R' tool generates good values for the internal field but mixes up the boundaries! Therefore you have to correct the boundary field after operating 'R'.
I hope these information are still helpful. But perhaps you already figured out a way to fix your problems. In that case I would be happy to hear your oppinion about OpenFOAMs RSTMs. Dis they perform satisfactorily? Any further problems?
Thanks pretty much
Sven
maysmech likes this.
svens is offline   Reply With Quote
Old   November 30, 2009, 16:32
Nat Trask
natrask is on a distinguished road
Relaxing R also helps a lot
i.e. add the following to your fvSolutions
relaxationFactors{
k 0.5;
epsilon 0.5;
R 0.5;
natrask is offline   Reply With Quote
Old   August 12, 2010, 06:10
Default Problem with the R-tool
spej is on a distinguished road
i got the problem.
spej is offline   Reply With Quote
Problem initializing Reynolds stress turbulence Vinicius Siemens 0 January 29, 2009 07:03
Turbulence: Reynolds stress equations kharicha FLUENT 0 March 16, 2006 09:50
Turbulence: Reynolds stress equations kharicha Main CFD Forum 0 March 16, 2006 09:48
reynolds stress in k-e model ayapan FLUENT 3 December 23, 2005 14:49
Reynolds stress Model Chimenti Martín Main CFD Forum 5 November 21, 2001 14:22
