I donbt want to use wall funtions How can I do it
Like Tree1Likes
  • 1 Post By hjasak
Old   July 26, 2006, 18:35
Default We are implementing a turbulen
Pablo Cornejo Olivares
pablo is on a distinguished road
We are implementing a turbulence potential model into OpenFOAM, in fact we already done it .
in short, I don't wanna use wall function. How can I get turn off this option?
pablo is offline   Reply With Quote
Old   July 26, 2006, 20:15
Default I don't know the answer to you
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
I don't know the answer to your question, but out of curiosity, are you resolving the flow all the way down to the wall (similar to Fluent's Enhanced Wall Treatment approach)?
msrinath80 is offline   Reply With Quote
Old   July 27, 2006, 02:48
Default The wall functions in OpenFOAM
Hrvoje Jasak
The wall functions in OpenFOAM are implemented by manipulating the generation term, the dissipation on the wall and wall viscosity. Have a look at the following file:
OpenFOAM-1.3/src/turbulenceModels/incompressible/kEpsilon/kEpsilon.C
in kEpsilon::correct() there are 3 #include files:
wallFunctionsI.H
wallDissipationI.H
wallViscosityI.H
The first one specifies G and epilon near the wall, the second one blocks out the calculation of epsilon in near-wall cells and the third one fixes the near-wall viscosity.
If you do not wish to use the wall functions, do not use this in your model. An example of a model with no wall functions is OpenFOAM-1.3/src/turbulenceModels/incompressible/LaunderSharmaKE.
As you can see, equations are solved without manipulation.
Enjoy,
Hrv
P.S. Which model are you implementing + how come we haven't already got it?
1/153 likes this.
Hrvoje Jasak
Old   July 29, 2006, 18:48
Default as soon as possible...
I donbt understand antopnieta OpenFOAM Running, Solving & CFD 1 January 15, 2008 15:44
ReadCHEMKINIII donbt work mavimo OpenFOAM Bugs 1 August 23, 2007 12:49
[blockMesh] Binary mode donbt work fabianpk OpenFOAM Meshing & Mesh Conversion 5 May 21, 2006 12:17
FoamX donbt show some cases derath OpenFOAM Pre-Processing 1 April 28, 2006 14:16
Donbt save bak adorean OpenFOAM 0 March 10, 2005 05:52
