Changing Temperature in Cyclic patch
Like Tree1Likes
  • 1 Post By ang_dipl_ing_fd
Old   February 14, 2007, 06:26
Default Dear All, I am running a LE
Daniele Panara
panara is on a distinguished road
Dear All,
I am running a LES of an oscillating pipe flow.
The pipe wall temperature is fixed: Thot.
The flow enters the pipe at a colder temperature (Tcold).
I would like to use cyclic boundary condition for the velocity and inletOutlet boundary condition for the Temperature. (The flow is reversing and I want that enters the pipe from the inlet or outlet with the same cold temperature Tcold)
Since this is not possible, I am wondering if it is possible to access the temperature values of a cyclic patch field and change them to a desired value.
In this way I can fix the temperature at the inlet and outlet to Tcold obtaining what I want..
Looking forward to get suggestions,
regards,
Daniele
panara is offline   Reply With Quote
Old   February 14, 2007, 12:21
Default i m new user for linux and i t
hamdi
hamcer is on a distinguished road
i m new user for linux and i try to install Openfoam ;and
can i install linux mandriva gcc or gcc required by OpenFoam ?
thanks for all
hamcer is offline   Reply With Quote
Old   December 1, 2010, 03:30
Nima Samkhaniani
nimasam is on a distinguished road
hi friend could you use different boundary conditions in cyclic patch?
i encounter the same problem i need cyclic for U and inletOutlet for T
nimasam is offline   Reply With Quote
Old   March 30, 2011, 12:28
Fatih
ang_dipl_ing_fd is on a distinguished road
hi nimasam,
you can set
inOut
type inletOutlet;
patchType cyclic;
inletValue uniform "value";
value uniform "value";
but you have to change the boundary condition back to cyclic after simulation, because paraview complains that there is an inconsistent patch and patchField type ...
this error appears even if you try to convert to VTK with foamToVTK.
BjoernFoam likes this.
ang_dipl_ing_fd is offline   Reply With Quote
[Commercial meshers] CreatePatch for build cyclic patch make OpenFOAM Meshing & Mesh Conversion 7 January 21, 2009 05:46
Cyclic patch in parallel calculations didomenico OpenFOAM Running, Solving & CFD 4 March 7, 2007 06:46
Arbitrary cyclic patch luca OpenFOAM Running, Solving & CFD 5 December 21, 2006 18:50
[mesh manipulation] Problem with cyclic patch and createPatch mattijs OpenFOAM Meshing & Mesh Conversion 12 August 24, 2006 05:57
Patch changing along simulation. Fabio CFX 2 December 4, 2000 06:31
