Tangential component of gradient of scalar field at surface
Like Tree1Likes
  • 1 Post By Sherlock_1812
Old   March 23, 2007, 07:14
Default Hi, To implement a thermo
Thomas Jung
tehache is on a distinguished road
To implement a thermocapilllary convection boundary condition, I need the gradient of temperature tangential to the surface. I know how to get the temperature patchfield, and also the gradient normal to the surface, but how to get the tangential component?
fvc::grad seems not to work on fvPatchFields, I tried this:
const fvPatchField<scalar>& TB =
lookupPatchField<volscalarfield,>("T");
const fvPatchField<vector> TGrad=fvc::grad(TB);
results in:
no matching function for call to 'grad(const Foam::fvPatchField<double>&
I could declare and compute temperature gradient as a volfield all over the volume, but I thought this should only be my last ressort, in order to save memory.
Thank you very much for any hint!
Thomas
tehache is offline   Reply With Quote
Old   March 23, 2007, 08:58
Default Unfortunately, calculating the
Eugene de Villiers
eugene is on a distinguished road
Unfortunately, calculating the volume gradient is the only out-of-the-box option. To calculate patch tangential gradients would require a finiteArea formulation, which is not currently integrated to the level that would make it simple to employ.
eugene is offline   Reply With Quote
Old   June 4, 2013, 03:27
Default Any luck?
Srivathsan N
Sherlock_1812 is on a distinguished road
Hi Thomas,
Were you able to implement grad T tangentially? I'm also having a problem with that.
Regards
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   June 4, 2013, 03:51
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi Srivathsan
Why do you need tangential component instead of normal one?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 4, 2013, 06:07
Default want grad T along a curved surface
Srivathsan N
Hi ehsan
I am also working on a similar problem as Thomas. I would like to have the gradient of temperature tangential to the surface for simulating thermo-capilary effect on a curved surface.
immortality likes this.
Old   July 4, 2013, 08:13
Srivathsan N
Hi Eugene,
Is it possible to take the definition of fixedGradient boundary condition and map it along a patch (to get a gradient along the surface)?
What does transformFvPatchField do? Does it help here?
Thanks in advance.
Regards,
Srivaths
Surface tangential gradient nzy102 OpenFOAM Post-Processing 2 December 5, 2018 10:50
from a vecor field to get a gradient of scalar dusky.he Main CFD Forum 4 March 30, 2007 10:08
scalar gradient roadracer Siemens 1 October 29, 2003 11:57
how to get a gradient of scalar xqy Phoenics 2 June 7, 2002 22:43
field by field decomposition vs. component-wise zhanglei Main CFD Forum 0 January 5, 2001 10:06
